Question about Xerox DocuPrint N17 Laser Printer
ROS Trouble with Xerox DouPrint N17
How much would it cost to fix the following problem?
With an old Xerox DuoPrint N17 laser printer, I entered "Config Sheet" on the Control Panel Display, which is recommended in the user guide to test the printer manually; Menus > Print Menu > Config Sheet > Enter
After some rolling noise without any paper feeding (although there were prenty of paper sheets in the trays), the following error message appeared on the display; ROS Trouble, Power Off/On.
Upon consulting an administration manual, I found the following descriptions; This message indicates there is a problem with the ROS controlling ASIC. ACTION: Power OFF the printer and power ON it again. If the message appears again contact your dealer or Xerox.
I powered it off and then after 1 minute I powered it on.
I repeated the above "Config Sheet" command but got the same error message.
I did not call a dealer or Xerox, because I would like to fix it myself. Therefore, I just want to know how serious the problem is and how much would it cost to buy replacement parts if it is easily fixable.
Thank you for your help in advance.
Katsu
  • Anonymous Mar 16, 2009
    I am from Brazil and I have tha same problem.
    President:
  • 2,072 Answers
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Posted on Dec 09, 2008
Oki B6250 displaying error: ROS failure call service.
ROS failure is the Laser Unit has gone bad and needs replaced.
Mar 10, 2014 | Xerox Phaser 6100/BD Laser Printer
Xerox phaser 6360 laser failure code 10
You may have to replace the laser unit. Code 10 is a warmup failure. You need to reseat the connector to the ROS Harness first. If the issue persists, replace the laser unit. Issue persists, check continuity between pins J15 and J151. If there is continuity, replace the Engine Control Board, if not, replace the ROS Harness
Feb 03, 2014 | Office Equipment & Supplies
Sys err ou463 Power off and on Xerox N17 printers
Turn the Xerox N17 printer off.
Unplug the AC cord from the wall-outlet.
Plug it back in.
Turn the printer on.
Do you still get the error-message?
Oct 09, 2010 | Office Equipment & Supplies
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
Error Code Call For Service
Most likely the laser has failed and needs replaced. Here is the documentation.
CA1 Indicates that the polygon motor in the ROS has failed.
arrwup.gifProcedure Enter output test, code 103, GP 10.
The polygon motor runs. Yes No Unanswered
Perform the following:
  • Check the connector CN26 on the Interface PWB. Refer to Wiring Diagram 4.
  • Check the harness and the pin connectors.
  • Check the Interface PWB for damage.
  • Install a new ROS, PL 9.10 Item 15.
  • Install a new Interface PWB, PL 9.30 Item 5.
Check at connector CN26 pin 4 on the Interface PWB for a low signal. Refer to Wiring Diagram 4.
The signal is low. Yes No Unanswered
  • Check all the connectors to the interface PWB are pushed fully home.
  • Check the interface PWB for damage.
  • Install a new interface PWB, PL 9.30 Item 5.
May 13, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
N17 printing "black" pages
If it prints fine at times, I would go to the Xerox.com site and dlwnload the latest firmware, and install that.
The problem really sounds like corrupted software in the printer.
Jan 30, 2008 | Xerox DocuPrint N17 Laser Printer
The following link has a software and drivers where you can select MacOS X and find the software and drivers. Unfortunately I found no installation instructions.
Docuprint N17 Link
I hope this helps.
Dec 15, 2007 | Xerox DocuPrint N17 Laser Printer
Driver for windows vista
If found that if installed the printer as a Xerox DocuPrint 4517 instead of a Xerox DocuPrint N17b then the printer works fine under Vista.
The only thing that lead me to try this was that I found that N17b and 4517 used the same printer cartridges, so I guessed they might be similar under the hood too.
Nov 21, 2007 | Xerox DocuPrint N17 Laser Printer
Xerox DocuPrint N17 Laser Printer Logo
759 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
