Question about JVC KD-S5050 CD Player
Cd is stuck
How do i remove a stuck cd /
  • 194 Answers
Takc cd player out remove cover and press on edge of cd to egect it manualy recommend replacing cd player
Posted on Dec 09, 2008
CD player problem. The CD stuck? Please advise
You may have to remove the unit and disassemble it to get access to the stuck CD for removal.
Dec 24, 2016 | Audio Players & Recorders
Pd-f805 cd scanner is stuck pd-f805
What exactly is stuck? Can you please give me as much specifics as possible, I would appreciate it very much
thank you
Oct 12, 2008 | Pioneer Audio Players & Recorders
How to remove cd stuck in player
Remove cd player and insert small tool to release stuck cd. Otherwise dissassemble cd player and remove.
Take to audio store and have them reome the cd.
Mar 20, 2015 | Jeep 2006 COMMANDER Radio a1z115973...
Cd player
You must remove the actual "faceplate" of the radio. Then use a small screw driver to "lift the cd" .. Many times it is just stuck. Good luck
May 13, 2013 | Car Audio & Video
How to remove stuck CD in CD player
Is there something inside the Player preventing it from not "Ejecting"?
If there was a Mechanical Failure inside the CD Player then you are going to have to remove the Player, and mechanically disassemble the Player to (1) Remove the CD, (2) Repair the Player for future use...
Apr 07, 2013 | 2006 Cadillac CTS
OEM CD player is stuck
have you tried disconnecting the battery cables? if this does not work, a CD may be stuck in it! You will have to remove the changer and open it up to remove the cd!
Aug 15, 2012 | 2005 Chevrolet Equinox
Cd stuck inside of laptop,
Look here: Remove CD Rom
Scroll down to see how to remove the drive
Open the tray slightly before you remove the drive.
Jan 26, 2012 | Dell Inspiron 1420 Laptop
I have a 2005 Ford 500. I have twoo CD"S stuck in the player. How do I remove them?
If the two cd's which are stuck, if you can see that cd's then pull the cd with pliers.Its a two mouth pliers to pull the things out.The cd may get cracked/ break while removing.But if the cd's are not seen or its very hard stuck, then in that case.The cd player has to be removed out of dash.Yes it will be time consuming, and will not be very simple.But once the player is out, its not much to do.The cd player bottom has few screws to be removed.Once you remove the screws, the complete top assembly will get lifted.You can say" complete casing" will be lifted.Once the casing is out.You will visually see the cd, and you can manually slide the cd out and remove it.---------- ---------- Click this link for cd player removing procedure from dash :--------- http://whoisbyme.blogspot.com/2011/08/how-to-remove-cd-player-from-dash-of.html ----------- This will help.Thanks.Helpmech.
Aug 03, 2011 | Ford Five Hundred Cars & Trucks
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
Cd stuck in the multi cd changer
You have 2 solutions. You can either a) remove the cover from the megachanger, which consists of removing about 6-8 screws. With the cover off, locate the stuck CD and remove it. Or b) press the "Open" button and remove enough CDs so you can reach into the unit and remove the one that is stuck.The solution you choose will probably depend on how many CDs are currently in the player.
Jun 28, 2009 | Audio Players & Recorders
JVC KD-S5050 CD Player Logo
575 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
