Question about Electrical Supplies
Lightfixture stuck I have an outdoor light that is covered with a glass globe. To get it off the globe is supposed to be turned 1/2 a turn, but I don't know how many times in the 20 years the house is standing that the bulb inside was changed. Right now it is completely stuck. I've tried using a knife to go around the place where the globe meets the metal of the part attached to the wall. I've tried wd-40 and I've tried gentle force (repeatedly) Now I don't know what to try next as these things are still not working for me. Thanks
  • 44 Answers
Try applying a little heat. That may help free it up. If there is a rubber seal in there it will soften it up and maybe fix your problem. There's maybe a 15% chance it will work but it's worth a try.
Posted on Dec 10, 2008
Replace park bulb.vt commodore
To replace the front parklight globe on a vt commodore can be a little tricky.
1.turn the lights on to see which 1 is inoperative once you know turn lights off.
2.open bonnet
3.go to side that is inoperative and on the back of the headlight you will see a round large plastic cover turn this to release it.
4.under the headlight globe there will be 2 wires flow these to the park globe socket gently twist and pull it out.
5.once the sockets out and you can see the globe ,pull the globe out of socket.
6.push new globe into socket
7.refit the socket in headlight
8.refit all trims
9.turn lights on make sure new globe is work..
Jan 22, 2014 | Cars & Trucks
How do i get light bulb cover off k9375 ceiling fan
The entire glass globe twists off (counterclockwise looking at the globe from below). It is kind of tricky, but if you apply constant pressure eventually it will begin to turn slowly, and then (1/4-1/2 turn) it will pop right off.
WARNING: I strongly suggest you have another pair of hands to help ensure the globe doesn't come crashing down to the ground, as it's VERY easy to do!
Nov 20, 2010 | Minka F603-WH Ceiling Fan
Is a globe outlet timer supposed to turn when plugged in? it is a "pin" type
Yes it turns when time passes.
If timer is not turning, it is broken and needs to be replaced, or the electricity is off.
Oct 2010
Add a comment if you need further assistance
Oct 28, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
I have lost my instructions and cannot figure out how to replace the burned out light bulb in my Minka Aire F603 ceiling fan unit; I can't figure out how to get to the bulb - can't figure out how to get...
Hi Bill. So far I have not been able to find a manual, but I will keep looking. In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion. If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body. Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it. I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual. If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you. BTW, nice fan. Paul
Oct 08, 2010 | Minka F603-WH Ceiling Fan
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Light burnt out
There are two ways to remove the globe. one is there are screws on top of the glass. two is you grab the glass and turn it counter clockwise. and some tomes there 3 metal clips that hold it in place you just need to pull the glass globe straight down.
Good Luck
Dec 27, 2008 | Dryers
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 | Ovens
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
Electrical Supplies Logo
103 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
