I have a Vicks Thermometer, the comfort flex one, and it is not working properly. Everytime I turn it on there is a small triagle on the left side... I dont have the manual, so I dont know what that means.
  • Anonymous May 22, 2009
    I also have a Vicks Thermometer, and it is not working properly. Everytime I turn it on there is a small triagle on the left side
Your battery is too low to allow it to operate properly, according to the manual. You can use a coin to remove the battery cover in the back to see what type of battery is needed to replace. Most drug stores like walgreens, etc, carry the watch type battery.
Posted on May 31, 2009
I also have the same thermometer. Ours is acting up as well, very upseting! I replaced the battery and it did not help.
Posted on Mar 11, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
I have two of these thermometers. What surprises me is that the manual suggests replacing the batteries (they come with a CR 1225) with a L41 or SR41. But, compatible batteries recommended are watch batteries! Watch batteries would be much too small. ALSO - the low battery warning for this thermometer is an arrow IN THE LOWER RIGHT. These thermometers have Lifetime warranties; contact consumerservice@kaz.com
The pictures on Vicks site are confusing as the manual for the one that looks like the thermometer (mostly white, lettering in blue) is actually not the manual you want. That thermometer uses a watch battery. The actual information can be found on their site kaz.com or here https://www.vickshumidifiers.com/shop/thermometers/vicks-comfortflex-thermometer-fever-insight - you want the Comfort Flex with Fever Insight on the far right of the thermometers page https://www.vickshumidifiers.com/shop/thermometers
I hope you find that info useful.
Posted on Sep 09, 2017
Is there a special thermometer for babies?
Try this thermometer from Vicks:
http://www.toysrus.com/product/index.jsp?productId=2266320
Jan 14, 2013 | Home
I need to know the proper insertion of the PS3 power eject button ribbon. Narrow ribbon with writing on one side.
small flex has blue tabs on each end. Insert flex with blue pull tabs in the up position. Small writing goes down!
Oct 23, 2009 | Sony PlayStation® 3 (60 GB) Console
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
I want to take the phone apart
remove cover and battery and sim etc remove 4 screws that you see using a opening tool or an old sim card run it round the first seam and it will seperate. remove the centre screw and the plug next to it and remove the block by lifting up.carefully free the camera button and volume flex from there position at the side then lift the lock on the thin flex at the top of the board. lift the board from the bottom of the phone and turn it over towards the top so that you can undo the plug flex then the board can be removed the small thin flex should just slide out. next remove the six small screws off the slide part and lift that clear,then remove the two screws that hold the last plate run opening too; up the sides and the plate will free lift it out from the bottom up.whats left is the screen and camera remove and replace what you need then rebuild in reverse using new flex
Jul 16, 2009 | Samsung SGH-G800 Cellular Phone
Where do i put the vicks in a vicks humidifier
you have to open the lid to the scent pad heater tray. the vicks pads go inside of there. now if you touch them with your hands you need to immediately wash hands after. cause of the fumes will be very strong. then close unit and turn on and it should work properly
Apr 16, 2009 | Vicks V4500 1 Gallon Humidifier
Leak in Exhaust Manifold after catalytic converter replacement.
it depends if they took the manifold off to do the cat converter job
If they did it is their repair cost as the job was not completed properly
if that was not necessary then they may have broken the flex bit just from the manifold
Jul 24, 2017 | 2001 Toyota Sequoia
Thermostat location on York Diamond 90 gas furnace
Augold, sometimes its best to set the thermostat where you "feel comfortable" . I.E. set it and leave it til you feel the need to be cooler or warmer.
A thermometer on a thermostat will not always be accurate and setting it will only get it within 2 to 5 degrees which is enough to "feel".
Now from the stand point of is it working properly????
Assume you feel comfortable and the heat stays on to keep you comfortable is their anything wrong with this? I assume this is the goal. Even if it says 90 (and you know its not 90) and your comfortable you could leave it alone and be OK. If this kind of thing is whats bothering you a new thermostat may not be much better, unless your ready to invest in one and accept it however it should be closer to the place youd set it. Id recommend an electronic type they are more accurate and level doesn't matter so much to these types.
If you want to set the temperature and are determined to go by a thermometer to "feel Comfortable" I recommend you buy an electronic thermometer and set it close by the thermostat. Make sure you have no lamps or other heat sources close to the thermostat area.
Remember the far end of a room or a chair by a window Especially with little or no curtains and on the prevailing out door wind will always feel colder and be colder than the area by the thermostat even if both are in the same room. If your too cold try running the thermostat up a few degrees. If too warm set it lower. The equipment doesn't care how cold or warm it is.You will not increase your utility bills to the national debt by being comfortable
If this helps please grade me accordingly and Good Luck.
Mar 03, 2009 | Weather King 10AJA3601AH Air Conditioner
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
5,330 people viewed this question
David Payne
David Payne
