Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Lost the rubber plug for my coffee maker basket.  It seals the drip hole when you remove the pot during brewing cycle.  Can you tell me where to get one?
  • tim834 Mar 13, 2009
    My seal has rotted and they tell me they do not supply parts for this machine. I am not happy.
  • Anonymous May 13, 2009
    la cafetera es nueva ponemos el agua en el recipiente pero no pasa por el agujero de goteo, no sabemos que hacer ? ayudenos
  • 30 Answers
I have one for sale. Contact me offline.
Posted on Jan 09, 2010
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Model # jwx23 mr coffee cleaning instructions
I couldn't find any model JWX23. So, since your question (as much as it is) is categorized under model JWX27, I'm going to presume you need the cleaning instructions for model JWX27.
With the coffeemaker off (with no lights on or with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 01, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
I am missing the small rubber bung that fits in the bottom of brew basket which allows the sneak-a-cup feature. Without this piece, the flow to the carraffe will not stop during the brew cycle when you...
this is Black & Decker's website that sells replacement parts for coffee makers. this older model isn't listed. it suggests you contact them via email for the part you are looking for. http://foxpartstore.com/t-contact.aspx
Jan 28, 2011 | Black & Decker SpaceMaker ODC325 Coffee...
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Leaks while filling
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Sep 26, 2008 | Mr. Coffee FTX49 12-Cup Coffee Maker
Swing-out filter basket with pause and serve..not functioning properly
Something wrong with your little 'grab a cup' mechanism. There should be 2 hinged plastic pieces (one of which contains the 'nipple', and one spring. The spring is shaped like a squared off 'U', and is about 2 inches long. Check to make sure all these parts are there, and move freely.
Also, check the basket. It dovetails onto a swing arm, and could be misplaced. If the basket is not positioned properly, the pot will not push up on the mechanism to let the coffee out. Make sure the pot is able to be pushed fully onto the hotplate and trip the mechanism as well.
Jun 29, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
154 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
