Question about Intel Ethernet 10/100 Network Adapter
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
Hello! We just purchased a Dell Inspiron 530S with Windows Vista Home Premium. Initial hook-up and operation with no problems. Internet connection via Verizon DSL using modem and Netgear wireless router WGR614 with LAN cable to PC, other notebook connected wireless.
When the PC goes to "sleep" mode, the router "turns off" and the wireless connection with other notebooks are lost, as well. Turning the PC on from "sleep" mode, the router connection is not recovered unless the PC do a complete restart OR we unplug then plug the LAN cable to the adapter then do a network diagnostic repair process. We went to device manager to configure the ethernet adapter not to turn off in sleep mode but the problem still exists. We even tried connecting the DSL modem directly to PC via LAN and "sleep" mode also disconnects internet connection when turned back on from "sleep". We already called Dell Support but cannot provide guided solution. Also called Netgear and they claim it is not router problem but (maybe) ethernet adapter settings issue. Please help.
Thank you.
Evan Vianzon
(714)767-5067 The ethernet connection to my Dell Dimensionsion E520 with Vista and an Intel 82562v 10/100 Mbps netwoek card is only running at 10 Mbps whereas everything else in my wired home network is running at 100 Mbps, including a computer that is 5 years older. It's the card or Vista or the combination, as the cable is fine.
  • 3 more comments
  • bcvc71 Jan 02, 2009
    I have the same problem on a new Dell Inspiron 530 running Vista Home Premium 64-bit. I have implemented many attempts at trying to fix the "wake from sleep connectivity" problem both at the router (a D-link di-634M) and at the network adapter card level -- I disabled IPv6 (both in regedit and by unchecking it in System Properties for the adapter), disabled/unchecked IPv4 and all settings relating to IPv4 in System Properties, disabled DHCP Broadcast Flag using regedit, and I adjusted the power settings so the adapter never goes to sleep (even if the computer does). Nothing has worked. Internet connectivity is still hit or miss upon reboot or upon wake after a sleep or hibernate state. The most recent driver update (12/2/2008) for the adapter from Intel has not solved the issue. If anyone knows of the solution to this annoyance, it would be greatly appreciated if you shared it. Thanks.
  • Anonymous Feb 08, 2009
    Hi, Dell Vostro 200, same NIC. Although I have no problems on Vista Home Premium 32bits, nor with linux kernels up to, I have the problem on linux kernels 2.6.26 to (current as I write this), AND on Windows 7 beta!
  • Anonymous Mar 15, 2009
  • dbahhadi Mar 15, 2009
    same exact problem, same computer by dell .new and no fix
  • Anonymous Apr 29, 2009
    I have the same problem. I found that you can scream at it and then unplug the ethernet wire and plug it back in. That seems to wake it up again. It's a pain in the but. I'm looking for updated drivers today, April 29, 2009 to see if there's a fix yet.
  • 50 Answers
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Posted on Nov 06, 2009
2 Suggested Answers
SOURCE: Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
Similar problem with XP Pro SP2, Intel 82562V-2 10/100 on Dell Vostro, Belkin G router. Windows will often say network cable is disconnected. I haven't isolated the problem to power management, but I wouldn't be surprised after seeing your post. Tried different cables, ports, and no other network devices have the problem. I just tried tuning off "reduce link speed during standby" in the network driver options maybe that will fix it. Before here are the things I would have to do to get it to work: unplug cable, wait (for several seconds), plug it back in, retry, retry, or restart the computer. When it isn't working there are no ethernet LED's on, if the lights come on when I replug the cable in then it works, but this does not always happen.
Posted on Jul 26, 2008
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapter
hope this help
Jul 21, 2012 | Dell Inspiron 1720 Notebook, Windows Vista...
I have a HP pavilion m8020n with Vista OS. I have internet for a while now and suddenly internet just went out. i talked to my internet carrier and we troubleshoot the connections. they said it might be...
2008 PC, shows it has modem too, a dial up. so 3 ways internet.
\there are 2 ways on to the internet (Ethernet and wifi)
aka, wired and wireless, respectively.
sure wifi router works,too, and is more difficult to setup. (im not going there)
try a new cable
try another router port yet, try cycling power only to the router?
sounds like your vista drivers are messed up ,
if another PC works , with ETHERNET cable to router there.then the router is working, test 1, passes.
that means this PC is failing
the PC has a control panel and device manager
see that and the network part? (not wifi , the wired network chip)]
vista 32b or vista 64bit?
your PC came with intel old
  • Interface: Integrated into motherboard
  • Technology: Intel 82562V
  • Data transfer speeds: up to 10/100Mb/s
  • Transmission standards:10-Base-T Ethernet
the driver is?
Intel 82562V
to make that chip work,
intel has it. 6 th down this list, Vista
load this driver. fixed. (from a working PC on the net)
then move it to dead pc and load it.
you are plugged in to X here. right.
or is there a card plugged in on the right, with RJ45 ethernet jack.
yes, you sure can add a new Ethernet card if the X jack blows out.
p5lple-fvyief5l4kybalhvncmspljg-3-0.jpg my DM ethernet port, im tying through it now...
mines a w10 gigalan port. so... is not intel like yours. ignore Realtek name pretend it says, Intel 82562V
May 23, 2017 | HP Pavilion m8020n PC Desktop
The mother board is burn up and the fan do not come on in my dell 530s computer, can i transfer my file to my new dell Inspiron 570mt computer
Remove the harddisk from the old PC and connect it to the new pc's motherboard as secondary harddisk then start transferring files to the primary harddisk of the new PC.
Sep 03, 2010 | Dell Inspiron 530 -Intel® Pentium®...
Windows 7 doesn't see network card after sleep
Go to control panel,system,device manager,network adapter,Right click on your adapter.
Then properties,power management.uncheck all power saver and wake options.
May 27, 2010 | Dell Ethernet Card Network Adapter
Inspiron 530s software problems
Try system restore if it works normally after this also turn system restore off and back on again as the problem could also lie in system restore information.
Feb 19, 2010 | Dell Inspiron 530s Desktop Computer
Dell optiplex boots directly into sleep mode
Try hitting F8 key to access the windows boot menu, Choose safe mode. If you can not get in to windows that way, you will need to reinstall windows.
Aug 17, 2009 | Dell Inspiron 530s Desktop Computer...
I have the same network card.
Never had this problem with Vista (32 bit) but recently switched to Win7 (64 bit) and had the same problem as you.
I solved by going under Control Panel->hardware->network card properties->power save and unchecking "Allow pc to switch off the device to save power"
Jul 13, 2008 | Intel Ethernet 10/100 Network Adapter
Intel Ethernet 10/100  Network Adapter Logo
2,107 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
