Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Fuel return line ;is it the same size or smaller than feed line
Had to clean carb due to sittng with gas .after cleaning prim bulb would not work unless saw was laid on it's side . small (short end ) of supply line was off and litterly fell apart when removed from tank.secured and replaced supply line but cannot find a new hose for the return line' the tube lines removed appear the sane size however the return seemed to be necked down in order to go into the small hole in the body.
Diameter of return is smaller and avaiable at the dealer or model car-airplane shops
Posted on Dec 14, 2008
Why does gas bulb collape and does not fill up and which gas line goes to which nipple on carbuerator?
The line with the filter should go to the carb, then from carb to suck side of primer and return to tank from the blow side of primer.
not sure if this will apply to your situation but is just what ive gleaned from experience
Dec 18, 2014 | Garden
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman line trimmer model 358791560 fuel issues
clean the carb really good. you can resoften the carb diaphrams by cleaning them with carb cleaner and rub them and dry them off then use some dish washing soap and rub them for a couple minutes. then just wipe it off. also make sure the screen in the carb is clean. you can burn the screen off to make sure its clean.
May 03, 2010 | Craftsman 25cc Gas Line Trimmer
Hi, can you tell me where each fuel line goes on an older Triton whipper snipper, (both ports on carby are at the same level, one 'big' one 'small' ).thanks....
generally the smaller line is the 'feed' line. It would have the fuel filter attatched to the end in the tank and go directly from tank to carb. The larger line would be the return line and rout from the carb to the primer bulb then to the tank.
If everything is working correctly you would see the fuel be drawn from the tank into the carb then leave the carb into the primer bulb and return to the tank.
Nov 26, 2009 | Garden
Replaced primer bulb and fuel lines, now it won't stay running
The smaller line is the supply to the carb. and should have the filter in the tank, with sufficient length to allow fuel pickup from the bottom of the tank.The larger line returns excess fuel and pressure to the top of the tank.By squeezing the bulb and watching the fuel lines you will be able to determine if you have them right on the carb.
Sep 27, 2009 | Poulan Featherlite Gas Blower, with Low...
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
187 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
