Replacing belt on washing machine
I need to know how to place the new belt on. When I tilted the washer to see what was wrong, I found the worn out belt on the floor. I have no idea how to get the new belt back on. The belt measures 19 1/2 inches long.
I would appreciate your help!!!
Thanks,
Margie
  • lindacevallo Jan 12, 2009
    Where is the puley. Don't you offer a picture instructional guide?
  • Anonymous Apr 22, 2009
    i dont know how to get the belt around the pulley motor
    Scholar:
  • 81 Answers
Hi!
Welcome to Fixya,
in replacing a belt please follow this step:
  • turn off and unplug your washer.
  • hook the belt first in drive motor pulley. ( a slot where your belt take place on top of the motor and sure that the belt is in place firmly to the slot of the pulley.)
  • start to hook the other end/loop of the belt to the tub pulley in one side of the pulley (it is more efficient in starting to hook the belt from inside to outside rotation.)
  • and hold the belt and rotate inside the pulley of the tub slowly
  • dont let the belt slip outside the slot of the pulley hold it firmly with your hands
  • hold the belt, clip to the slot of the pulley
  • but don't hold the belt alone or don't hold the belt in between of the pulley.
  • hold the belt inside the slot of the pulley in the tub pulley and rotate slowly. until it fix to the slot of the tub pulley.
If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
aclamonte
Posted on Dec 09, 2008
  • Washing Mach... Master
  • 3,463 Answers
Without knowing the make of washer I can only give you a general idea of how to fit a new belt.
If it has a removable back panel then remove it, and then simply .
fit the belt round the motor pulley first and ease it round the drum.
If you can't get in from the back, tilt the washer towards you and again get the belt round the motor pulley and force the belt round with the drum pulley turning it slowly by hand.
Watch your fingers.
Hope this helps.
Plz leave feeedback.
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
My washer won't spin and the belt is fine. What do I do?
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Other than lose or worn belt there are various reasons that cause washing machine not to spin.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | GE WBSR3140DW Top Load Washer
Drum will not spin in any cycle
Hi
Then check for lose or worn or crack in belt. If these signs appear, remove the old belt by tipping the washing machine over on its side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Aug 05, 2011 | LG WM1814CW Front Load Washer
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
May 03, 2011 | LG Washing Machines
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
The central piece doesn't move when the washer is working only in the spinning mode
Have someone help you look under the washer. Tilt it up and back and look underneath. Do you see one belt or two? Is it worn? If the motor and belt is good then transmission is bad. Call places with you make and model for an estimate. P.S. Have you noticed grease stain on your clothes after washing?
May 07, 2010 | Whirlpool LSR8433K Top Load Washer
When my washer goes into spin cycle it makes really loud noise and spins really slowly?? Can u tell me what is wrong?
The drive belt is worn, tilt the machine back to access the belt on the underside, simply pull of and replace the belt - no tools required, the motor pulley is spring loaded and will move to give some slack or tension.
Nov 27, 2009 | Admiral AW22 Top Load Washer
Tilting of drum
if it is noisy then its loose drive belt, worn bearing .regards
Oct 11, 2009 | Amana DLW330RA Top Load Washer
Our brand new bosch exxcel washing machine is jumping all over the place. We have checked it with a spirit level and it is level. The feet are tight. The washing is loaded level. What is wrong ?
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt.
Sep 12, 2008 | Bosch Washing Machines
Replacement seals
Washing machines are generally very easy to fix
Instead of typing out directions on how to do it, I found a website with some directions that should work with your machine, and you can always find more, washing machines are pretty simple machines. If the belt looks worn, it wouldn't be a bad time to replace it too. Also, clean everything up as you take it apart and it should be almost like brand new.
here is the link I found with pictures and everything, let me know if you have any questions while doing this, good luck
http://www.kichline.com/chuck/fixit/washer/white.htm
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
2,163 people viewed this question
Top Washing Machines Experts
