Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Code What does it say when the code is DL. The machine does not lock so it won't start. The alarm goes off. What do we need to do?
  • Rose Wood Mar 02, 2007
    Thank you so much. The door was find but the item on the top was broken. My husband ordered the part and it was fix. Thanks you saved us a lot of money.
    jcpenni99
    President:
  • 878 Answers
Jc, First check to see if the door lock pin is broken. This will be the little black actuator just above the switch. If that is ok, remove the top by removing the 3 torq screws on the tops back side. Slide the top off toward the back. Look at the main board in back on the right side. The second and third harness from the right are the door lock main switches. Reset these harness's into the board (unplug and plug back in). The harness that is 5 from the right will be the door lock solenoids, do the same. This is a 3 wire harness, if you have a ohm meter wires 3 to 2 two left ones should read 60 ohms. Wires 3 to 1, each end should read 60 ohms. This will ohm out the lock solenoid. Getting back to the first part, you can use a toothpick to plug the actuator switch temp. if that is broken, Catriver..post back.
Posted on Feb 26, 2007
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore smartwash error code dl and f? Won't start.
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the problem is solved. Please get back to me if you have any other questions.
Kevin
May 26, 2011 | Washing Machines
Alarm sounds and F dL flashes on w/p front loading washer
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Sep 11, 2009 | Washing Machines
When I hold the button for it to start it clicks and starts flashing F then dL It will not start washing
The "f" part is saying that you have a fault, and the "dL" part indicates that your control panel thinks that there is an issue with your door lock. The brain will attempt to lock the door six times, then flash the error code. Press pause/cancel twice to clear the alarm. Then check your lock. Usually, it's something loose on the lock or catch; it can be the wiring to the lock being loose, or the control panel may have a fault. Start with the lock, and work back to the control panel.
Best regards, --W/D--
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashes a code of "dL" and "F"
NOT MUCH INFO TO GO ON, BUT HERE GOES" A DL CODE IS A DOOR LOCK ERROR, A F CODE USUALLY HAS A # AFTER IT AND WOULD INDICATE AN ERROR. W/P HAD SOME MODELS THAT REQUIRED CHANGING THE DOOR LOCK-MECH AND CONTROL BOARD . HOPES THIS HELPS, PLEASE CONTACT ME @ HUBAPPLIANCE@COMCAST.NET AND PLEASE RATE ME.... THANKS
Jun 24, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
