Question about Harman Kardon FL8350 5-Disc CD Changer
Harman Kardon FL8350 CD Changer
My Changer only seams to want to read disc 2 and play disc 2. If I try going to another disc it wants to go threw its anologing procedure and then it displays, "no disc". After that I am unable to get back to disc 2 for play. the only remedy to get it to play disc 2 is to power the device off and unplug it. I believe this resets it because when I power it back up I can get it to play disc 2. I have a hard time wanting to believe this is a lazer issue when it will play. Could this be more of an anologing problem with a sequencer, or the chip? Or is this all done with the lazer. I dont want to toss it if it can be fixed for 50 or less. Its worth it to me. thanks
  • Anonymous Apr 05, 2008
    Mine will only play Disc 1...strange.
  • netwrx4u Sep 06, 2008
    I was given the hk disc changer and amplifier from my boss at work. The amp works but the cd changer has the same proplem of not even recognizing any disk in the tray. All 5 discs are skipped and the display says not disc. Maybe the lazer is dead or something... Can anyone please help, I dont want to throw it away because I need a cd changer for my entertainment center...
    Thanks a bunch!!! Brian@
    Netwrx4u@yahoo.com
The screw in the center of the tray is too tight, loosen it a bit.
Posted on Nov 13, 2009
Try lifting the left side of the player, I tried that last night, and it behaves different, in horizontal mode it tries to load each disc before it finds that there is no disc, but when tilted it just scans the slot (with som optical sensor) and finds the slot empty without loading the disc
Posted on Jul 08, 2008
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
HAMRMANCARDEN WILL NOT READ DISC FL8350
You can try a cd cleaning kit in attempt to bring it back to like, if this fails the cd pickup assembly will need to be replaced, a costly venture.
Jul 21, 2012 | Harman Kardon FL8350 5-Disc CD Changer
DVD 30 turns off when I put a disc in and it reads it.
I understood your problem...Harman Kardon BDP1 BluRay Player generally it cause due to lens problem and data processor it may be creates a problem.
you have one option to use lens cleaner CD which removes dust from the lens it may be helpful to you.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 20, 2011 | Harman Kardon BDP1 BluRay Player
The drawer in our Harman-Kardon HD 950 CD player won't go all the way in. It gets to the point where there's about an inch sticking out, then re-opens and tries again. This is a fairly new unit. Is there...
It turned out that a CD had slid past the drawer and into the case of the CD player. Once I removed it everything was fine. I should point out that mine is *not* a 5-disc drive, but a single-disc drive, model HD 950.
Nov 11, 2010 | Harman Kardon FL8385 5-Disc CD Changer
Have no instructions
Go to retrevo.com, register and download it for free.
You need to finalize the disc for players to read it.
May 03, 2010 | Harman Kardon CDR20 CD Player
STUCK Door
You will not get shocked if you stay away from the power supply, I have worked on several of these,the cd's are pilled up behind the door, remove the screws ,remove the cd's ,and hopefully you did not strip the cd turntable gear. You will know if you the gear is damaged, when you power the unit up after removing the cd's .the turn table assembly will rotate very jerky.or slow ,or It might not move at all..if so let me know i can help you with that..good luck
Nov 02, 2008 | Harman Kardon FL8350 5-Disc CD Changer
Harman Kardon FL8350 5-Disc CD Changer Logo
507 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
