Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
DCR HC20 The touch screen does not work. I went to the calibration screen and pressed the "x" like the manual told me...It does not work too, Please help
    Scholar:
  • 107 Answers
I believe the flexible cable from the LCD screen to the main control was cut or lose because the action of open and close the LCD, in any case It require a qualifier Tech trained from Sony to replace this FC
DO NOT tampere it, You might damage the LCD screen
Posted on Dec 09, 2008
Hi having problem setting date ,month ,time on camcorder . The touchscreen is not working when i press against screen
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 22, 2011 | Sony Handycam DCR-HC20 Mini DV Digital...
I have a Handycam digital video camera recorder- DCR-HC30. The camera sat in its carrying case at room temperature for about two years without being used. When I went to use it, the touch screen would...
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Feb 08, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
MY SONY CAMCORDER DCR-HC20 TOUCH SCREEN IS NOT WORKING
Note: 8 represents the reset button on the above figure.
Jan 15, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 30, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
The touch screen calibration on my Sony DCR-HC20 doesn\'t work? I keep touching the little \'x\' and it keeps asking me to do it in all three places but never completes the calibration process and the...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Nov 16, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
SONY DCR HC 20
due to open & close screen your screen belt has damage. send to us for service.
Jun 18, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Touch screen problem
Please see the solutions on the same model I posted earlier
Nov 01, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
LCD Touch Screen
Connecting flexible wire between LCD and main board of camera seems cracked/ broken. Please replace it with new one.
Jul 31, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
LCD touch screen
Take off the screws at the left side of the lcd screen, than open gently the case. Use a air can than spray for cleaning. The lcd screen is now back on duty...
Aug 15, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
938 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
