Hi...there is a constant hum on the set. It groans loudly always on startup but this seems to go away in time. It will shut down unexpectedly and the lights flash and then it will startup...always with an awful groan! It also is reluctant to startup at times..lights flash and then it will come on... but only when its good and ready!
Help!!!!!
It sounds like the colorwheel motor is bad, check the colorwheel and make sure its still good but im pretty sure its the motor going out
This would be your color wheel motor and the fan assembly. They should have self lubricating bearings, however if these bearings are failing you will get these kinds of noises.
I hope this helps,
Thank you
Shuttle83
http://www.electron-age-technologies-llc.com
The fluorescent inside make
humming sound naturally.
Like when you turn on a lamp, and some lamps make
a low humming sound.
If your sound is unusual it indicates that you need to replace lamp and fan .
If its DLP tv..
TV makes a humming noise.
Step 1: Power on the TV and wait for the picture to be displayed.
Step 2: Reset system and mute the TV.
Step 3: Can the noise still be heard?
Step 4: Adjust TV volume to normal listening level. Can the humming noise be heard over the audio 6~12 feet away from TV?
Step 5: Stand near the TV and listen if the humming is from lower center of TV?
Step 6: If unsure of where the humming comes from,
power off the TV and listen to the humming. Make sure noise is audible
to confirm this step:
Good luck...
One of the suggestions is to replace the optical module... are you referring to the color wheel, optical engine or is there a replaceable module I am not seeing?
