Question about Garmin nuvi 350 GPS Receiver
NUVI 310 I tried to update my maps to the 2008 Map Source City Navigator 2008 Australia. I uncoded the maps on my PC and transferred to GPS successfully. Now the previous maps are gone (2007 version) and I get a warning saying "can't unlock maps". How do I fix this problem so I can access the maps?
  • 2 more comments
  • trevor_chate Dec 09, 2008
    I have tried soultion one and it doesn't work.
    I had Mapsource City Navigator Version 2007 Australia loaded on my Nuvi 310. I tried to install version 8 of the same software. I successfully unlocked the maps on my PC and then transferred the maps to my GPS inbuilt memory. Now I have no maps at all. I get a warning saying"can't unlock maps'. I tried one of the solutions which was to delete the gmapsupp.img. file in the Garmin directory It does not work. Are there any other solutions?
    Not at all. It made no difference.
  • Anonymous Mar 30, 2014
    Update to maps is in a loop trying to backup.
  • 19,396 Answers
The map code had not been validated, and the all maps had been probably erased.
When this happen you need to call Garmin to sort out the problem.
Call Garmin Australia toll free Monday – Friday: 8:30am – 5pm EST at :1 800 235 822
Or follow indications on this page (click).
Posted on Dec 09, 2008
    Genius:
  • 1,239 Answers
Hi
Have you registered the mapping software with Garmin? You have to register it, they will provide you with the unlock key, and then you enter the unlock key in your software so your maps can be used in your Garmin GSPr. Each code is specific for the software and the Garmin unit.
  • ABHISHEK.C
    ABHISHEK.C Dec 09, 2008
    are you referring to a PIN lock or locked maps?
  • ABHISHEK.C
    Secondly, you may need to call GARMIN to talk to their tech support... they can straighten out this problem if you've already paid for the map update.
    1 800 800 1020
    You should register your unit on GARMIN's website, it will speed the process.
  • 734 Answers
Maybe there is enough to remove \garmin\gmapsupp.img from nuvi. But be carefull, this can be a valid map, so better make a copy befor removing.
  • futureloginn
    futureloginn Dec 09, 2008
    All GPS that supports NT maps, do also work with non-NT. Not the other way around.
    To see that it works you can activate both GPS and Mapsouce in demo modes.
    Go in to MapSource and select:
    Utileties -> Unlock Maps -> Next -> Yes I have 25-carachter key -> Next -> Next ->
    In the field "Enter 25-character code" type inn "DEMO" -> Next -> Close.
    This sets MapSource in Demo and unlocks all maps you have installed.
    Then send the map to the GPS that you like to look at.
    This will set the GPS into Demo modus. (Works only in emulated nodus)
    To get out of demo modus, remove the "DEMO" key from Unlock wizard and
    transfere any map you like to the GPS, or deltete the \garmin\gmapsupp.img file.
  • futureloginn
    try a reset -----
    Hard Reset is performed in the Maintenance
    Mode:Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
    Place a fingertip on the upper left hand corner of the touch screen andkeep it there while turning the unit on, a prompt should read " Do youreally want to start in maintenance mode?"
    Select the yes button.
    Enter your PIN if enabled.
    Main Maintenance Mode screen should have 4 selections:
    System information
    View Diagnostics
    Clear User data
    Clear Waypoints
    Choose "Clear Waypoints". After some time the unit should reboot.As to firmware upgrade:
    Upgrading firmware:
    click on Garmin's site
    download, install and run "WebUpdater"
    Follow on screen instructions.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
  • Garmin Master
  • 6,487 Answers
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
  • Mark Gil
    Mark Gil Dec 09, 2008
    If you already tried those solution and it didn't work, you can try to reload again the update that you have installed and then after that reset the unit....
    President:
  • 2,110 Answers
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’. In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
How do I get the devise to work here in Australia
probably does not have maps installed for australia.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
Need to up date maps
Create an account at myGarmin regsiter your unit ID number this will allow you to unlock the maps that you buy. You then have two options the first requires you to have an NT 2009 or 2008 map already installed.
nüMaps Lifetime™This will cost you £99.99 and is a on off payment Remember — this map update can only be used to update the preloaded maps that came installed on your Garmin GPS device. For example, a Garmin GPS device preloaded with North America maps only cannot be updated with a nüMaps Lifetime Europe Map Update, and vice versa. Check product compatibility. nüMaps Onetime™ This will cost you £79.99 and does not rely on having a map already installed.
The City Navigator® Europe NT comes on a DVD or you can download it.
LOL
Oct 03, 2009 | Garmin nuvi 200W GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Loading Australian Maps on Nuvi 200
She can purchase the City Navigator Australia DVD and load the Australian maps onto an SD card. Insert this into the unit and she'll then have both S Africa and Australia maps.
Mar 10, 2009 | Garmin nuvi 200W GPS Receiver
I am updating my nuvi 200 with map update 2009 of city navigator north america nt. Canada is not loading to my gps through my computer. Looking for a solution.
when updating from the city nav update disc, it will only update the maps currently on the unit. Since Canada isnt included, it will not add it on. What you need is the Pre-programed City navigator chip for Canada. Normally retails around $59.99
Aug 04, 2008 | Garmin Rino 530 GPS Receiver
Gamin nuvi 310
You can send your unit to Garmin and they'll reset it. You will need to include proof of purchase.
Sep 19, 2007 | Garmin Map Source City Navigator
Map data availability
"I tried to load the new 2008 City Navigator but the update was interrupted."
You deleted your previous maps, therefore there are no maps on the unit. Try reloading the maps again and this time let it continue all the way to the end. It will take a couple of hours depending on loading all maps or only certain states.
Aug 22, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
890 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
