Question about Logitech QuickCam Messenger Web Camera
Regarding display webcam image in my own website
Dear sir/madam,
Currently i want to add the webcam video files in my own website. i am using logitech quickcam ver10.5.1. I dont to know how to capture video files in logitech camera?
There is a option to capture a still image only.So plz help me to solve my problem
  • Anonymous Dec 10, 2008
    i ned a web cam can u help me
    Genius:
  • 1,061 Answers
GO TO http://www.logitech.com/ Download the control panel for you make and model n os.RICHARDM69
Posted on Dec 14, 2008
Webcam is not showing any video at all!
Connect your webcam
Launch the logitech webcam toolbar from your desktop or if you chose not to install the shortcut - launch it from "All programs" or from your C drive - Programs and files.
Open the Quick Capture menu (2 film frames pic)
Check your image here
If it shows white - you have a logitech/computer software problem
If its OK you have failed to configure it correctly to whatever program you are using it in.
Did you install the support software required to run Logitech cameras - Directx 10 ?
Apr 24, 2010 | Logitech Webcam
How to reset my panasonic digital video camera
The answer to this is probably in the manual - have you looked there ? If not, careful perusal of all the options in the menu system should point you in the right direction.
May 08, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
How to save photoshop image in web
dreamweaver can't display PSD (Photoshop) files so you will need to export the file for web. To do this from Photoshop, press CTRL+ALT+SHIFT+S to save the file for web. Choose your settings (all of the displayed settings will let you view the file in dreamweaver) and then save your new file.
Let me know if you need more info on this.
Dec 16, 2008 | Adobe Computers & Internet
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
QHM500LM USB PC CAMERA DRIVER SETUP NEEDED QUANTUM... how can i install webcam drivers QHM 500-LM
i have no software quantum qhm500lm usb web cam.driver. plzzzz help how can play my web cam. plzzz guide me
Nov 16, 2008 | Creative Labs WebCam Live!
I have lost my cd of web cam
Normal 0 Go to this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System. Then you will get your download driver.
Hope this helps. Bud
Aug 29, 2008 | Logitech QuickCam Pro 4000 Webcam
I lost my webcam cd installer
how can i download cd installer of my logitech webcam quick cam*8.3.2( window) and quick cam *8.0.1( mac os*)
Aug 22, 2008 | Logitech QuickCam Pro 4000 Webcam
Not able to install webcam
Normal 0 Try disconnecting the Camera from the USB port and reinstallthe software program. When the program asks you to connect thecamera to the USB port, do so and it should work.
Nov 01, 2007 | Computers & Internet
Logitech QuickCam Messenger Web Camera Logo
222 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
