to those having the camera problem with the sidekick 2, the diagnostic mode is a great solution, how ever it did not work for me. but...what i did, was leave the phone plugged in, and go to the diagnostic screen as "wormuniverse " describes uncheck all that are checked, then check the disconnect battery, while leaving it plug in go a head and diconect, the phone will "buzz". let it come back on. check your camera if it still does not work repeat two or three times untill the camera "reboots". doing this worked like a charm for me.
Quite simple, and t-mobile was no help: This solution worked for me, YMMV. Hit the menu key > System settings. Within system settings, press menu, shift, and d key. This will open up the diagnostics program. Run all of the checked options. When that completes, return to the diagnostics program again, and select only "Battery disconnect." I left the phone in this state overnight, and the camera worked the next morning. Hopefully this is helpful.
Was this helpful?
Yes
No
Solution #3
posted on Feb 21, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i still can get it i press the buttons and it dont work
im having the same problem with my sk2, whenever i go to take a picture, it says that there is not enough space, and don't try to delete things off your phone to make it have more memory, it still WONT work, there must be a manufacturer problem with the camera. The first day i got it, which was about a week ago, it worked perfect, then i went to use it later on in the day, and it wouldn't work.
Exactly the same problem here - however, there was a -short- period of time where it just suddenly seemed to be working again, it lasted a few weeks, then no-go again... back to the black screen, and "your device is low on memory" I've tried uninstalling all installed apps, deleting all additional information I didn't need (calender events, notes, to-do lists... etc.) all to no avail.
my sidekick 2 camara says that there is not enought space and to reset it but that dosnt work
Comment by Guest, posted on Jan 04, 2008
I have the same problem it says low on memory
Same here screen goes black and I get the same message. Hard/Soft Reset does NOTHING, Running Diagnostics does NOTHING. There's an issue with the wiring near the camera.. Still trying to fix but haven't had any results.
Comment by Guest, posted on Dec 14, 2007
Mine is dong the exact same thing and that diagnostic solution didnt work 4 me. Any other suggestions??
Comment by Guest, posted on Nov 15, 2007
Everytime i take a pic it says your device is low on memory. Please restart and try again. but it doesn't work wat do i do
