Question about Pioneer DEH-P44 CD Player
How do i hook up my pioneer deh-p44 cd player without a wire harn
I have no wire harness comin from the deck and needa no witch little prong is witch
5 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: Changing the clock
From the Pioneer Electronics website; How do I set the clock on my single CD player? For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
Posted on Sep 03, 2007
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
Posted on May 27, 2008
SOURCE: color code
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/50622945INSTALLATION%20MANUAL%20DEH-P3600.pdf
Posted on Jul 21, 2008
  • 23 Answers
SOURCE: Pioneer DEH-P6800MP wiring diagram
DIRECT FROM PIONEEER
Posted on May 16, 2009
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Apr 16, 2011 | Pioneer DEH-P2900MP CD Receiver...
Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
Aug 17, 2009 | Pioneer DEH-P6400 CD Player
NO POWER TO MY DECK
Hello clarky909,
On your Alero, the 12V constant wire is ORANGE and should connect to the YELLOW wire coming from the DEH-2300 wiring harness. 12V switched on your Alero is YELLOW and should be connected to RED coming from the DEH-2300.
Hope this helps.
Jun 01, 2009 | Pioneer DEH-2300 CD Player
Wire codes for a pioneer deh-p4400
right rear- purple wires
left front- white wires
right front- gray wires
left rear- green wires
BLACK STRIPE NEGATIVE ON ALL
red- 12volts switche
black- ground
yellow- 12volts constant memory
Apr 28, 2008 | Pioneer DEH-P44 CD Player
Pioneer Deh-p44 cd player- AUx input?
ya http://www.amazon.com/PIE-PIO-P-RCA-Pioneer-Adapter/dp/B000P9SLCA
Mar 05, 2008 | Pioneer DEH-P44 CD Player
Pioneer DEH-P640 Car CD Player
Does the player has the 12v needed on the rem side to light the player? If so then there maybe a short in the lamp area, if you tapp on player do light come in and goes out?
Sep 10, 2007 | Pioneer DEH-P640 CD Player
Pioneer DEH-P44 CD Player Logo
90 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
