Question about Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
I have a Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer . It has enough tape in it. Problem is that there is nothing printing on it. Batteries work fine.
Really don't know what can be done to make it function properly.
Can you help?
Gigi
    Problem Solver:
  • 7 Answers
Www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Posted on Apr 09, 2009
2 Suggested Answers
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
My Brother PT65 label maker powers up and when I push print...the rollers turn but the label does not print or come out.
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
May 20, 2015 | Brother BRTPT65 PT-65 Label Maker Printer
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
How can i get a p65 instruction manual
Hi halliemain,
Here's the download website for the user guide for Brother BRTPT65 P-Touch.
Click on the link for the download: BRTPT65 P-touch
Hope this helps!
Good Luck!
Thank you for using Fixya!
Mar 11, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to Find.com and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
It is printing a solid black band throughout the entire tape, and it prints inches and inches of it, much more than the text. Help
You may have ink on the print head. Try removing the back and taking out the tape. Using a dry Q-tip gently wipe the print head which sits just opposite the black rubber roller.
Also confirm your tape is not old. If possible, clean the print head and try using a new tape.
Aug 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Dec 28, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
804 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
