Question about ASUS Computers & Internet
Setup screen displayed, than blank screen & blinking cursor, frez
ASUS M2A-VM mother board
AMD 754 processor
On start up system displays ASUS setup menu, then quickly goes to a blank screen with a blinking cursor. System then hangs up.
  • 365 Answers
This is the same experience i had came across.when the RAM is not placed correctly in the slot the computer screen will get blanked. i had heard that when there is compliant with the hard disk the same problem will occur.try to check whether the RAM is correctly placed in the slot and check the supply to the hard disk and check whether the red cable from the hard disk is placed correctly.thank you
Posted on Dec 09, 2008
  • 395 Answers
If you have more then 1 ram chip try to boot with just a single ram chip, in the 1 slot then the other. if that doesnt work try the other ram chip if you have one.you might also want to be sure you have Grease Thermal Compound on the cpu as it might be over heating,remove extra pci or pci-e cards and see if it boots with them removed. im betting it a bad ram chip or a heat problem
what cpu you using with it ?
  • Bernie Reeves Dec 09, 2008
    or change the Boot device priority to be cdrom first, the hard drive 2nd that way it will boot yor windows xp cd first so you can install windows or any other os from a bootable cd
    President:
  • 2,110 Answers
Try to change Boot device priority in BIOS (for that u have to press F2 or Del button while booting)..as 1st boot device is Hard drive..
If this wont solve ur problem you should re install os by a bootable OS CD..
  • ASUS Master
  • 6,487 Answers
Try first to reset the BIOS your MOBO if you have the user manual for it you can find the steps there if not post back so i can give you the steps for it....
My asus p5pe-vm mother board display shows in key board but not in monitor but sometimes it shows display in monitor
get the motherboard out of the case and clean the AGP slot with contact cleaner and amd clean the graphic card contacts to.
Jan 17, 2011 | ASUS P5PE-VM Motherboard
The south chipset bridge of my Asus k8n-vm motherbard heats up
85 to 95 is ok. Anything higher than100 is pushing it. If possible add a fan to the side of the system case (Best choice) or you can buy a south bridge fan. You're MB doesn't have holes in the MB to attach a chipset fan but you can still attach a cooler on to the chipset. Like this fan; http://www.newegg.com/Product/Product.aspx?Item=N82E16835103155
And you'll need this as well for a good bond; http://www.outletpc.com/c2019.html
Enjoy!
Mike
Jun 12, 2010 | ASUS K8N-VM Motherboard
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
CPU Upgrade
Hi there.
Here is a list of processors that board will support >>>>>
http://www.cpu-upgrade.com/mb-ASUS/M2A-VM.html
Good luck and thanks for choosing FixYa!!
May 27, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
I lost my mother driver software cd.Model of my mother board is M2A-VM HDMI.Please send me it.
Dear friend Go there http://support.asus.com/download/download.aspx?SLanguage=en-us
You may see top the left corner Search by model please put the model number here
your model is M2A-VM Then click the search button.. you may put your operating system then you find all for download thanks.
Mar 26, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
Dec 09, 2008 | Computers & Internet
Drivers for Asus mother moard
you can go to asus.com where you can download drivers for your board.
i have found drivers for your board there.
Mar 19, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
