Question about Lexmark Wheelwriter 1000 Typewriter
Return key doesnt work properly
I have an intermittent problem with the carriage assembly when i hit return. if i get past the half-way point the carriage will only return to the half way point. it wont go all to the left margin, and sometimes when i get all the way to the right margin it wont return at all. it just goes down to the next line, however, if i turn it off and then back on again it will reset to the left margin.
  • 328 Answers
Do you hear any grunting noises when you tab or return? If so, then DickyO is right. A few drops of oil on the silver support shaft should help. Also, clean the shaft after oiling then apply a couple of more drops.
Posted on Jan 12, 2009
  • Lexmark Master
  • 3,594 Answers
Try putting a little light oil on the silver shaft that the printer slides on, WD40 works well.
DickyO
Posted on Dec 09, 2008
When i hit return, why doesnt the carriage go all the way back
Try spraying a little WD40 on the silver shaft that the carrier slides on if that doesn't do it you will have to spray the bearings on the carrier motor located in the R. rear corner inside the case.
DickyO
May 13, 2014 | IBM Wheelwriter 30 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
My carriage return is stuck between 70 and 80 and I don't know how to get it back to 0 to 10. I hit return and the carriage goes back to between 70 - 80.Can you help me?
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. key.
DickyO
May 20, 2010 | Nakajima AE-710 Typewriter
AE-710 Typewriter: My carriage return is stuck between 70 and 80 and ...
Return to the L margin, press don't hold the mar rel key, backspace to the desired location, press left mar. key. The R. margin works the same.
DickyO
May 18, 2010 | Nakajima AE-710 Typewriter
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Coronomatic 2200 carriage return stops advancing
It sounds like you are coming up against your right margin. By hitting release you are merely bypassing the margin. You might try resetting your right margin by clearing it all the way to the right side of the carriage first then resetting it to where you want it.
Jan 28, 2009 | Office Equipment & Supplies
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Dec 27, 2007 | Nakajima AE-740 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
