Question about Sharp AR-5320 Black and White Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
Sharp Tech Support said clean drum surface with wadded-up paper. (The drum initially appeared a little dirty, but wiped clean with dry cloth) Using paper left fine-line scratches along the surface of the drum and the lines continued to print on the page.
    Problem Solver:
  • 10 Answers
If the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Posted on Dec 09, 2008
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
Lined Copies
If the line is only when you feed the original from the top feeder (not when you place the paper on the glass)....clean the narrow glass (called the **** glass) under the feeder on the right hand side
If that is not it new drum and/or blade is called for
Oct 28, 2009 | Sharp AL 1631 Copier
Konica di620 ghosting and streaking
What about the starter/developer last time its been changed? Upper fuser/fixing roller (Hot rollers) don't forget to clear counters once those parts are installed.
Aug 05, 2009 | Sharp AL 1631 Copier
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
Gray lines on the copies
If the toner is low that would cause a problem. If the drum is damaged that would cause a problem too. If you have recently (past month) printed successfully than you might have issues with copy surface. Does the line come when using the auto feeder? Replace/ remove/reinstall the toner cartridge and clean the copy surface. Repost if this does not solve problem.
Nov 01, 2008 | Sharp AL 1631 Copier
Sharp AL-2040CS Copier
The cycle count. I think it's set for 50,000 copies on that machine. Are there any lines on the drum?
Has any of the green surface on the drum worn out?
Sep 12, 2008 | Sharp AL 1631 Copier
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AR-5320 Black and White Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
