After running the philips mp3 player disk pc doesnt reconize it
  • 8,596 Answers
Unplug the mp3 player from computer.
Uninstall all Philips software using the add/remove function.
Reinstall the installation CD.
Then and only then, plug the mp3 player into computer.
Posted on Dec 09, 2008
Why doesnt my gogear sync with my media player
your gogear has corrupt config files! you must power it off, and connect it to your pc while holding the menu button, and continue to hold it until the computer reconizes it as a usb mass storage device. when an auto play option opens, it will allow you to select "Open with folder to view files", select this option and navigate to the "CONFIG" folder. you must then delete all files inside of the config folder, then once your disconnect and reconnect your player, it should work perfectly,
Jul 11, 2009 | Philips GOGEAR SA6045 MP3 Player
My player says memory corruption and if i format it,it doesnt work .if i connect it to my pc it finds it but i cannot copy any file onto it because it doesnt give it memory
Never follow any advice on this forum that suggests that you "format" a GoGear. It may be the correct solution for other mp3 players, but not this one. Your last hope to save your player is to get the updated version of the Philips Device Manager from Philips website, and run an Update. You may or may not have to run a Repair afterwards.
-Tha Mp3 Doctor
Mar 04, 2009 | Philips GOGEAR SA6045 MP3 Player
My philips gogear 2gb mp3 player will no accept any format
maybe try uninstall program on pc then put instalation disk back in and reinstall
Dec 31, 2008 | Philips GoGear SA3125/37 MP3 Player
Mp3 player not reconize
Put the Clip into hold (left-side switch down!) and press the center button down while connecting the USB cable
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
Help Help Help
Install and run the firmware upgrade software from the product CD.
Select repair/restore option and follow on-screen prompts.
Feb 20, 2008 | Philips GoGear SA178 MP3 Player
Yellow triangle
Install and run Device Manager from the product CD.
Select the repair option, and follow the on-screen prompts.
NOTE: ALL FILES LOADED ON TO THE PLAYER WILL BE LOST.
If this doesn't work then it may be that the hard disk is faulty. There is an easy way to find out. The following procedure allows the player to connect to the PC as a removable drive. If the Pc reads the drive, then the drive is ok.
Connect the HDD1630 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
CLICKING HARD DISK is usually a sign of a problem with the hard disk. If this is the case it will have to be replaced.
The HDD16X0 series use a standard 6Gb Microdrive which are readily available, and much cheaper than the official Philips replacement. The new drive would need to be "Repaired" using the Philips Device Manager.
Nov 18, 2007 | Philips HDD1630 MP3 Player
 Grubhead
Grubhead
