Warning from my Canon MP700 printer almost full waste ink tank
What do I do? How do I empty the waste ink tank? I don't even know where it is.
  • 734 Answers
Waste toner must removed after a period of time open up your printer and you can see a small container inside. dispose properly the toner inside and clean the container with vacuum, do not use water, gently reinstall again into your printer and reset.
Posted on Dec 09, 2008
  • 19,396 Answers
You need to reset a counter, only rarely you have to empty the ink tank, I will give you the exact procedure in ten minutes.
  • Ginko
    Ginko Dec 09, 2008
    You find several reset codes here. the waste ink tank is located inside the printer, on the lower left hand corner watching from the back.
    Apart resetting the code, the waste ink tank should be emptied , to avoid risks of ink overflow.
    To empty the ink tank you need to ake apart the printer, and you usually risk to spread ink all over the place, as the sponge is soaked.
    The best thing to do is having the job done at a local repair shop , or call the canon number listed on the owner manual.
    Below you find Canon contact pages for UK and US:
    Canon UK - Contact
    Canon USA: Contact Us
  • 10,515 Answers
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
  • taran_2005
    taran_2005 Dec 09, 2008
    Also,
    off the printer and open upside cover,see 'the waste ink absorber if there any spunge pull that
    and empty the waste ink from sponge or waste ink absorber
    ok
    again cloused the upside cover
    ok
Printer says"waste ink near full"
The waste ink is a set of sponges inside the ink jet that absorb ink during the printhead cleaning.
For now you can keep printing by pressing and holding the printer's On/Off button for one second. Then wait 10 seconds and press the On/Off button again. Wait until the printer finishes cycling before trying to print again. See Canon's support page for details: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp700#ServiceAndSupport . Search for Waste Ink Full.
When the waste ink tank is full, then you will not be able to print until the unit is serviced. Canon will service this for you. (Free except for shipping if the printer is under warranty, standard $$ otherwise) However under normal use, the waste ink full counter should be reached its limit near the expected end of life of the printer. Additional failures may occur soon.
This is a messy job and may be a lot more work than you want to do. Have plenty of newspaper to absorb the ink if you try this. You need to disassemble the printer to reach them. One set is under the area where the printhead sits when the printer is idle. The other is further down in the center. You will need to remove a few small screws to access the bottom set. Once you get them out, blot off most of the ink and then run under water until the ink is completely out of the pads. Blot the areas where the pads sit of the excess ink as well. Then dry the pads (you can use a blow dryer to speed this step). Then reassemble the printer. (Alternatively, order replacement pads from Canon)
See http://www.fixyourownprinter.com/forums/inkjet/45693 for additional comments from others who have tried this.
Next you can reset the counter. (Do not do this reset before cleaning or replacing the ink pads; waste ink will smear everywhere.)
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing [Menu] then [Copy] then [#]
2) Select TEST MODE. (using + or - keys)
3) Press the [OK] key.
3) Press the [8] key. (TEST MODE)
4) Press the [3] key.
5) Press the [0] key. (INK COUNT).
6) Press the [OK] key.
7) Press the [Stop/Reset] key
9) Press the [ON/OFF]
I hope this helps.
Feb 20, 2011 | Canon MultiPASS MP700 All-In-One InkJet...
Message on printer "Waste Ink near full"............. Where is the waste ink tank?
Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink FULL Reset (Should work with MP700/730/750)
This reset should be used once waste ink counter reaches full and lock-out occurs.
- To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
  1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
  2. Select "TEST MODE"
  3. Select "[8] ETC.."
  4. Select "[4] EEPROM CLEAR"
  5. Select "[1] INK COUNT"
  6. Press the [OK] button.
  7. Press the [Stop/Reset] button (Exits Service Mode)
  8. press the [ON/OFF] button (which resets the printer)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
MP700 waste ink near full
waist ink tank near full
cannot clear by pushing resume
what's the next step to get the printer fix
Rey
Apr 12, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Canon multipass mp730 / waste ink near full
Ok try using the codes
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 30, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
47 people viewed this question
k24674
jasbo
jasbo
