Question about ASUS Eee 4G Notebook
Wont turn on reset button?
My son put phone charger in usb port now wont turn on is there a reset button?
  • 1 more comment
  • seandavisson Dec 09, 2008
    it wont turn on, Im looking for reset button but cant find it.
  • benleves
    benleves May 11, 2010
    you don't have a reset button on laptop
    for the reset on laptop hits the same button power
    you need to press it 5 sec and you can't try to unplug ac power and batteries
  • benleves
    do you tell me that your son whant to charge your whit your usb phone charger.
    Master:
  • 461 Answers
Sounds like damage to the USB port. Did the phone ever charge?
Look into the USB port and check for bent connectors - you may be able to straighten them. To reset - unplug AC and battery and press and hold the power button for 6 secs.
Posted on Dec 09, 2008
Ate pro max error says unfortunately stock android has stopped. How to fix?
1. Charge The iPhone
It may sound easily, but you need making sure your iPhone's battery is charged enough to run the phone. To test this, you can plug the iPhone into USB charging port or the main USB ports on a computer. Let it charge for 15-30 minutes and hold down the on/off button to turn it on. Maybe it turns on automatically. If you doubt recharging doesn't work, it's possible that your charger or cable is faulty.
2. Check The iPhone Cable And Charger
Maybe you need trying charging your iPhone with another cable and another charger. Then try charging someone' s iPhone with your cable and your charger. If the iPhone cable and charger has problem, you must pay attention to.
3. Restart The iPhone
If the iPhone cable and charger are no problem, you need to restart your iPhone. Pressing and holding the Sleep/Wake button for at least 10 seconds, until the Apple logo appears.
Note for iPhone 7 and 7S users: Press and hold the Sleep/Wake and Volume Down buttons simultaneously to force a restart.
4. Restore The iPhone
If you want to restore the iPhone, you make sure you've got the latest version of iTunes. Then connect your iPhone to your PC and select Devices in iTunes.
If you haven't backed up your iPhone you will be told to do so now. This will back up all the data and settings on your iPhone. Then click on restore, wait until your iPhone completes the restore process and resets to the Home screen.
5. Reset
Click on Settings then General then Reset All Settings
This will perform a reset of all the settings to the factory defaults. The data or content on the iPhone is unaffected.
6. Put iPhone Into DFU Mode
Your iPhone may not turn on. This can happen after jailbreaking or when you installed an iOS update without enough battery life. When you face this problem, you can put your iPhone into DFU mode.
Plug your iPhone into PC.
Press the on/off button for 3 seconds.
Press the on/off button and Home button together for about 10 seconds. (iPhone 7 press volume down)
Release the on/off button, but keep holding the Home button for about 5 seconds.(iPhone 7 press volume down)
If the screen stays black, you're in DFU Mode. Follow the instructions in iTunes.
7. Force device into recovery mode
Beware: Recovery mode erases all the data on your device. Only follow these steps if you have a recent back up on iCloud or a computer.
Turn off your iOS device.
Plug the USB cable into your computer - but not into the device
Hold down the Home button then plug the USB cable into the device
When you see the Connect to iTunes screen (below), release the Home button.
More information about phone repair guides and tools, you can choose vipfixphone.com.
Dec 08, 2017 | Android Cell Phones
I have a yamaha av receiver HTR-3065 My unit wont turn on since my son put a faulty charger in the usb port
Sorry he put a live port into u.s.b as the usb input is powered he might have blown a fuse in the main board
Sep 28, 2016 | Yamaha Audio Players & Recorders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Wont reset wontrecharge wont turn on ... replace battery?
I would check to see if the usb port is bent inside. Take a magnifier and a light to see if the port bar is bent, if so use a small thin screwdriver to either bend up or down slightly so that the charger fits tight. My Kindle did the same thing but this saved the day for zero cost. Or do a hard reset with a paper clip on your reset button. If all else fails call Amazon tech support.
Feb 10, 2016 | Tablets & eReaders
Wont charge. i plugged into so many usb cables and box chargers and light wont turn on nothing charges it
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Mar 01, 2011 | HTC G1
My iphone not charging and on..help me!! :(
1. Check your charger with another iPhone. If it is working, your battery may be dead. If not, replace the charger. You can buy some at www.amazon.com or any other site you like. 2. Try charging the phone on your laptop via USB cable. Hope this helps. If so, please rate. Thank you
Jan 15, 2011 | Apple iPhone Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
Moto Q Sprint Phone wont turn on
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
Feb 11, 2009 | Motorola Mobility Moto Q
Env Phone wont start up
Well, in my experinece, one of two issues. You said your charger port is bad. Thats not good. It will give you enough juice to barely turn the phone on and it goes out. MOST phones will do that. IF you know your charger port works, try a new battery, if it doesnt you have to get the charger port fixed as it will just constantly act as if the phone is dead, even if you put a new battery in it, it will blink on, touch a button eats up the battery bars and dies. craigslist.org usually has alot of cell phone repair people on it. depends on your community.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
ASUS Eee 4G Notebook Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
