Question about IBM ThinkPad T21 Notebook
Have an IBM T21 and when I turn on the pwr button only the Z button is lit up and nothing on the screen.
  • 7 more comments
  • Elik015 Dec 19, 2008
    I have the same.
  • paprkut Jan 01, 2009
    i too havethe same problem
  • Anonymous Jan 05, 2009
    I have the same problem.
  • Benito Coronado Jan 05, 2009
    I have the same problem too.
  • dozier_marc Jan 06, 2009
    Same problem
  • simonWins Jan 21, 2009
    my ibm thinkpad T21 did not turn on when i pushed the start button...no light, no sound, nothing running....
    any ideas anyone ?
  • Gerlo G Feb 26, 2009
    IBM THINKPAD T21 NOTEBOOK. Unit was working fine. Today I went to turn it on and all the lights turn on, but did not boot up and screen was black...... Hopefully a minor issue?
  • Anonymous Mar 07, 2009
    Same problem :(
  • Anonymous Mar 17, 2009
    Tried that and still the same thing. have tried replacing the HD and hoped it was that but no avail.
    Hoping someone would have this resolved by now as these laptops are a bit old.
You need to go on your laptop with it pluged into the mains when doing it and if its does it hold F4 down for ten seconds then let go.
After that quickly turn off the power on the laptop (not on the mains) and switch it back on after about ten seconds hopefully it works, I have had this toruble before and this resolved it.
Posted on Mar 17, 2009
My thinkpad t21 just died! It started 2 weeks ago when I would turn it on, sometimes the screen would not light up or come on. I could see in the shadow, if there was a light on the screen that it was...
Remove the battery and power cord. Hold the power button in while connecting the power cord hen the battery. This will reset the power distribution settings. If this does nor resolve the issue then you need a new power supply. With this machine a new computer would be less expensive.
Dec 15, 2009 | IBM ThinkPad T21 Notebook
It makes three beeps and the fan will be running and the power light will be on no screen display when you leave it running and switch off and on it works fine
check out your memory ram, try to replace it and switch on again,..also check your cmos battery, if it is low, then replace a new one....last options are to check and change the processors..try it
Oct 28, 2009 | Computers & Internet
Won't start up
Hi there.
If the beep is a short beep then there is nothing wrong with the PC, just enter the bios utility, set the date and time, save the changes and exit the bios.
The computer will restart and should boot straight through to windows.
Please post back if you need anymore help or advice.
Good luck and thanks for using FixYa!!
May 24, 2009 | IBM ThinkPad T21 Notebook
IBM thinkpad A21 won't start up
1# remove the battery from the thinkpad and ac adapter.
2# hold the power button for 40 seconds.
3# plug in the ac adapter and turn on the botton.
4# see it for works what trying to do to thinkpad is recyle the power .
give it a try and see if it work if it doesnt let me know
Nass
Apr 14, 2009 | IBM ThinkPad T21 Notebook
How to remove the display on IBM T21 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Feb 03, 2009 | IBM ThinkPad T21 Notebook
IBM T21 doesn't start
try to start it with the battery out by pluging it straight, the battery is dead and its causing problems
Mar 13, 2008 | IBM ThinkPad T21 2647 Notebook
Nothing appear on the screen
Remove any devices connected and power it on by itslef, either on battery or power source, if it doesnt work, it may have bad processor, When they go bad most laptops wont boot period.
Feb 18, 2008 | IBM ThinkPad T21 Notebook
IBM T21
i have the same problem. actually its a common problem for many T21 and other old IBM laptops.
i searched that you have to take all power (batery, adaptor)
press the power 10 times and press it for 30 secs then reinsert the battery or adaptor and try to power it on.
they say its done to discharge a certain capacitor that got overcharged after overcharging the battery.
that worked for me before but now my T21 wont start any more with this process.
May 20, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad T21 Notebook Logo
173 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
