Question about Clarion N.I.C.E. P200 GPS Receiver
Fm not working
I just bought a clarion NICE gps and i cant get the FM frequency and internal speaker button to show up. what do i do
mattozan
  • 555 Answers
SOURCE: lost gps signal and cant get it back.
Where are you?
Posted on Apr 10, 2008
SOURCE: Clarion Nice 430 not giving current GPS position
I had the same problem. If you go to the about screen you will probably have an old firmware issue. Mine was 3.1.2007. Clarion is supposed to be sending me an update disk since I bought the unit online and it did not come with the most recent firmware/software. If you bought it from a retail place they should have the disk and can upload it for you. Mine only worked until I powered it down. You were supposed to be able to go to the advanced screen, clear all data, power it down and back on. That worked one time and once I shut it down again it never worked for me again. I reloaded the original disk and again it worked until a power down. You just need the new software.
Good luck
Posted on Apr 11, 2008
SOURCE: Clarion
i have a clarion nice 430 with some software glitch but it has a pristine screen.
Posted on Dec 11, 2008
  • 6 Answers
SOURCE: N.I.C.E Lack of Updates Interested in CLASS ACTION LAWSUIT?
There is an RAR file with the update free, download it to you 2GB SD card, then pop it in
Posted on Nov 05, 2009
kapishtech
  • 2272 Answers
SOURCE: I'm installing a Kenwood KDC-138/CR
Red wire ignition,yellow wire to battery and black wire to ground. This has to be connected. red is hot,yellow is neutral and black is ground. Check out.keep updated.
Posted on Sep 04, 2010
The voice is just not working, all else is fine, no, the mute is not on...??
Do you have the unit set to internal speaker or FM Transmitter? Go to the Volume section from the menu, FM Trans, disable FM Transmitter.
Feb 13, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
CLARION MARINE SPEAKERS CONE DETERIORATED
of course, the only problem is finding someone to do it, and is the speaker really that nice and worth the money
Mar 21, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
Jul 20, 2008 | Tomtom GO 720 GPS Receiver
Clarion N.I.C.E. P200 GPS Receiver Logo
15 people viewed this question
Top Clarion GPS Experts
Will Halftowaite
perdue40
Are you a Clarion GPS Expert? Answer questions, earn points and help others
