Question about Saeco Royal Exclusive 30153 Espresso Machine
How do I remove the burr grinder for cleaning? Saeco Royal Exclusive
  • dilco Mar 01, 2009
    I removed the burr grinder for cleaning but I am having problems re-installing the grinder to the correct grind position. I can describe how to remove the grinder and clean out the burr grinder. Removal is as follows:
    Turn off the power to the unit
    Remove the (2) screws holding the coffee bean canister to the machine
    Remove the coffee bean canister
    Remove the rubber bushing on to p of the grinder assembly
    Gently lift up on the burr grinder adjustment lever, pulling straight up. (Rocking the lever from side to side may help.) It should lift traight off with a snap.
    You will see a red mark and blue slash on the inside of the grinder unit. There is also a blue slash and a red dot on the adjuster ring around the grinder unit. Observe the position of the red dot in relation to the adjustment lever just removed. You will need to put this back to this position on re-assembly. (This is the information that I need to know also).
    Once you have observed and referenced these positions turn the outer ring until the blue slash marks align with each other. Now you can lift the inner portion of the grinder out of thew machine and clean out the clogged and over packed coffee out of the reservoir. (A vacuum may help you out with this.)
    Re-assemble in the reverse order.
    Hope this works for you.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
This is not a hard procedure, but you have to feel comfortable with DIY projects.
First empty the bean container. Vacuum out any remaining beans. Remove the philips screws from the hopper. Lift the hopper off. Vacuum any loose beans out. Remove the rubber gasket. You may clean this with a mild soap solution. Remove the grind adjustment lever- lift straight up with index fingers under the flange. Turn the outer ring with the holes counterclockwise, lift the center ring with the ears straight up when the outer ring is loose enough. The ring with the ears is the upper burr. Clean with a brush. Don't use water or other solutions. Vacuum the beans chamber and brush clean. Replace the upper burr ring matching the ears with the grooves. Turn the outer ring clockwise until it stops. Pull the inner ring to be sure it is locked. Now turn the outer ring back 13 clicks. Replace the rubber gasket. Replace the grinder adjustment lever- drop the lever flange inside on the outer ring with the lever grip loop over the top at #4. Press the flange with two fingers while supporting the outer ring from below. This seems tricky, but be patient. Replace the hopper and screws. Do any grinder adjustments while grinder is running with beans, it may take a few shots to be back at your preference grind! Good luck!
Posted on Mar 27, 2009
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Saeco Incanto "grinder blocked"
provide in detail about your problem ..........
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
My Saeco Magic Comfort Plus machine will not grind the beans. The grinder just spins and spins
You can try to remove all beens, then with the use of paint brush and vacum cleaner try to clean the grinding entry and gringing burrs. If
this not help then you need to revove top cover panel and so you can clean grindr more closer, check also the burrs they might need to be replaced.
Sep 03, 2010 | Saeco Coffee Makers & Espresso Machines
I received a new lower burr grinder part from SAECO for my machine but no instructions on how to replace it. I know how to clean and replace the removable grinder part that fits into this. Do you have...
Hi
If you only got the lower burr it won't work. They should be matching burrs.
If you don't do it right, you will damage the grinder. You need a #10 Torex bit.
Insert the bit into the screw in the middle of a very clean grinder. Turn clockwise to loosen. Once the screw is out, pull the burr out, but be careful. There are ball bearings and springs under the burr. Make sure that everything is clean before reassembly. There are 3 holes in the bottom of the grinder. The springs go into the holes first. Then the ball bearings set on top of the springs. Place the new lower burr on top of the springs. A washer and the corkscrew go in next. Insert the screw in and with the bit in place turn (with a little down force) clockwise until the screw drops into place, then turn counterclockwise. It should turn fairly easy. Once you start putting pressure on the springs, try to turn the corkscrew. There is a notch that it slips into in the bottom of the grinder. Once it locks into place keep turning the screw until you start to turn the burr. That should be tight enough. Now reassemble the top burr and adjust.
May 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco Royal Cappuccino maker that is signalling "beans Empty" is making the grinding noisd but the beans are not actually entering the grinder
The grinding burrs need cleaning if we consider than nothing have damage them.
First and simple advice is to use the vacum cleaner and try to **** everything from the grinder and try again the machine. If the problem is insist then you need to sesasemble the grinder and clean the hole grinder with the vacum and also with a wire brush.
Good luck
Mar 23, 2010 | Coffee Makers & Espresso Machines
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Looking for user's manual for Saeco Stratos Expresso Machine
I have a user instructions to this machine.
I will try to upload it to Royal exclusive 3053 page.
/Mirran
Aug 12, 2008 | Saeco Royal Exclusive 30153 Espresso...
Coffee Grounds
Grinder needs to be adjusted or it popped out of its shaft.
Grinding the coffee too fine or the grinder backing up will cause tension between the upper burr and the grind shaft casing.
Once this happens 9 times out of 10 it will relieve pressure by popping itself out of the shafting or worse yet, cracking the shaft itself.
If you open the side of the machine where the brew drive is and you see grinds all over the place, there's a good chance that's what happened.
Needs to be sent out for repair.
Mar 15, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
528 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
