Question about HP Scanjet 4400c Flatbed Scanner
HP4400c Yielding Poor Image quality
I installed an HP ScanJet 4400C. The original install disk fas for Windows ME, hoever I downoaded the correct softwware for XP - Version - Precision Scan Pro 3.1. When scanning excellent quality photos I am receiving a rainbow type line typically horizontal on every scan. I have adjusted the scan dpi as well as using the Decreen function and have not been able to get around this. Any suggestions?
I was having the same problem- dpi didn't have any effect.
Changing the SHARPEN to "High" and Descreen worked for me. My research showed the alternative fix was a new scanner, or at the very least a new bulb/power supply (which would probably cost more than a new scanner)
Posted on Aug 26, 2009
Drivers HP scanjet 4400c for windows 7
This worked for me:
Do NOT connect scanner before these first few steps
1. Download & save win xp drivers from HP website: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=28447&prodTypeId=15179&prodSeriesId=28441&swLang=8&taskId=135&swEnvOID=228
The 63.4mb file is the only one you'll need
2. Right-click on the saved file and go to its properties. Under the compatibility tab, set the file to run with win xp service pack 3. Apply changes and close properties dialogue.
3. Right click on the same file and choose 'run as administrator'. Accept any windows prompts that may appear and let the program & drivers install.
4. Once the software has finished installing, connect the scanner to your computer (via USB) and turn the scanner on.
5. Restart the computer without unplugging or turning the scanner off.
6. Your scanner should now work fine with the HP Precisionscan Pro utility.
Oct 31, 2011 | HP Scanjet 4400c Flatbed Scanner
How do I find hp scanjet 4400c for win 7
Hi whitecloudy !
Hp doesn' t support your unit anymore since Windows XP and it's a shame . Here are 3 workaround solutions :
solution one:
You can get your unit working in WIA mode if you can follow this :
make sure your XP ( yes XP ) driver is correctly installed .
Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP PrecionScan Pro , program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
solution two :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
solution three :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
Have a nice day ,
Best regards,
Fanaudi .
Feb 08, 2011 | HP Scanjet 4400c Flatbed Scanner
Windows 7 driver
If you can't find it with google, it doesn't exist.
Jan 23, 2010 | HP Scanjet 4400c Flatbed Scanner
Scanjet 4400c does not work on windows vista
ftp://ftp.hp.com/pub/softlib/software3/sj668/sj-21881-1/sj668du.exe
Jul 14, 2009 | HP Scanjet 4400c Flatbed Scanner
HP Scanjet 4400c
The same for me but I don't have a program to instal a thing. I find there is no down for my scanner can you help so I can still use my scanner.
Oct 23, 2008 | HP Scanjet 4400c Flatbed Scanner
Win vista doesn't accept hp scanjet 4400c downloaded driver
Hi there from Germany - English isn't the best but got the same problem solved so give it a try:
- first connect scanner to computer without having the drivers already installed
- next computer claims driver cd put in yours from XP or select downloaded XP-driver
- reboot
- try if scanner works - sometimes they do already
- if not head over to System management or system control what it's called in english
- choose add device and choose scanner
- now Windows tries to install a xerox-driver - allow this
- reboot
- and now it should work - if not sue hp! (But buttons for direct printing etc. might not be working anymore - except via the software itself - no more via the buttons
Hope I could help
Oct 21, 2008 | HP Scanjet 4400c Flatbed Scanner
HP Scanjet 4400c Flatbed Scanner Logo
252 people viewed this question
Seeker5211
Seeker5211
