Question about Sharp 21B-S10 21" TV
Sharp 21 dig, color
Good Day I have a issue with my TV for some reason a lock pircure is located on the bottom left corner and I cant get any chanels Please help Lost
    President:
  • 1,284 Answers
Your parental lock is probably activated. That is most likely the V-chip doing its job locking out depending on the rating (PG,PG13,R etc) of the program.
Posted on Feb 26, 2007
My sharp aquos tv screen color gone and the colour settings is blocked and cant be used..what will I do to return its tv screen color
If the adjustments you need are blocked out either it is that something that is connected to the set for signal (cable box, sat box, receiver etc) is now in control or in some fashion you have locked out the option yourself--I would have a good look at the owner manual first and if that fails call sharp with the model number----if you recently hooked something new up to the set or moved set from one location to another it may have happened then.
May 19, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
What's the reason to cause the TV shows up only sounds but not pictures?
I may have a work around for you. I also have this model and the same problem. after trying many many sequences of turning on and off with setting changes I came across something that works for me 100% of the time. Turn off the tv. Place your left and right hand on the top corners of the tv. flex gently back and forth. turn tv on. this works for me. I can only say that this tv has some quality control issue(s). it will be my last Sharp product. this was a lowest bidder produced by a company other than Sharp with a Sharp label on it. good luck.
Aug 15, 2010 | Sharp Aquos LC-32D40U Television
Remote control codes
MY BPL TV SHOWS TU OR TV LOCK,AND FN BUTTON IS NOT WORKING HOW CAN I UNLOCK IT
Sep 13, 2009 | Belkin S-VIDEO CABLE 16 FT.
Screen locked can 16 (model HX270S)
Hi there, I think you might have the priority channel switched on. Look for a button labeled PRI or somthing like that, press it once or if that fails press for 3 seconds.
Apr 24, 2009 | ICOM Informatique Icom IC-F11S 5W 2ch VHF...
Num lock is locked !
In the bottom left hand corner there is a Key that says Fn hold that down, then press the key in the top right hand corner that has says NUM LOCK it will be printed with a TOP set of words and a bottom set. Typically two different colors. The Num Lock light should go out
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Apr 11, 2009 | Samsung NC10-14GW Notebook
Locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Sep 14, 2008 | Haier HTF20R21 20" TV
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
COLOR ISSUE,
either the tube degause cirt is faulty or you have another appliance close to the display,sometimes changing the position of the display will cure this.
Dec 07, 2006 | Gateway VX 1100 (White) 21 in.CRT...
Sharp 21B-S10 21" TV Logo
105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
