Question about HP Photosmart C912 Digital Camera
Simple fix, please help!!!!
The only thing wrong with the camera is that the on/off switch won't work. I have contacted HP about this, but unfortunately, they no longer offer repair service or parts for their digital cameras. Is there anything I can do to fix this problem myself? Maybe a homemade rig or something since I can no longer get a new part for it. It seems like a simple fix, but HP customer service has been absolutely no help at all. Someone please get back to me asap!!
5 Suggested Answers
SOURCE: Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Posted on Apr 12, 2008
SOURCE: HP Photosmart R725 camera error.HELP!
Smack it a couple times, gently. You have nothing to lose, AND, I swear it works!!!
Posted on May 11, 2008
  • 54 Answers
SOURCE: Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Posted on Nov 24, 2009
  • 102366 Answers
SOURCE: HP Photosmart R742 Lens error report code R740-033
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
My camera does not respond when i try switching it on. The battery is charged and cannot still turn on. Could it be the battery?. Please help me.
May 30, 2011 | Agfa Photo Optima 100 100 Megapixel...
Hi i have Nikon coolpix 5900. Yesterday after
Make sure the battery contacts, both inside the camera and on the battery, is clean. You can clean them with a qtip and alcohol. Also, check the battery voltage, it could be getting old. Here is a good blog of things to check with this problem:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Good luck, and hope this helps.
Jul 04, 2010 | Nikon Coolpix L11 Digital Camera
MY lens on my camera wont go down and now my camera wont work
If I recall correctly, there was a recall for this issue and alot of people had this problem in the past. We contacted the manufacturer and they refunded our money. Here are some other things you can try. Hope this helps.
Here are some simple things to try first for a camera that won’t power on. They won’t work for every case, but they’re worth a try:
If you get it to respond, and if next the lens doesn’t want to retract:
Oct 26, 2009 | Polaroid T730 Digital Camera
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Powershot A75 lens got stuck midway
If the above don't work, then you may possibly be experiencing a lens error. Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 06, 2008 | Canon PowerShot A75 Digital Camera
Canon a520
Jan 18, 2008 | Canon PowerShot A520 Digital Camera
Camera will not switch on.
Oct 29, 2007 | Canon PowerShot A530 Digital Camera
HP Photosmart C912 Digital Camera Logo
49 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
