Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
All (4) video inputs are bad
First the component inputs went fuzzy then I switched the cables to the video, within days they had the same problem. Erratic picture movements.
    Problem Solver:
  • 10 Answers
Possible change your AV cable...you can't use the same component cable for the normal AV input...component cable (RGB - RED,GREEN AND BLUE),normal AV cable is RED,WHITE,YELLOW.
GOOD LUCK.
Posted on Dec 09, 2008
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Mitsubishi wd-57831 the tv was in the garage for a year because the bulb went out. I replaced the bulb and now the picture is fuzzy. Could this be a dust accumulation problem?
Possible but not real likely--check first to see if any rear audio/video input works well or not--if all else fails and rear inputs work you can route the signal there with a cable or satellite box that has those outputs on it to one input on the rear of the set.
If not a connection issue (cable fitting etc) it might be a bad tuner and the rear inputs will bypass that.
Dec 17, 2012 | Televison & Video
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Tv is fuzzy
TRY USING BOTH INPUT EG: TRY TUNER THEN TRY A/V INPUTS AND COMPARE THE SIGNAL IF BOTH ARE BAD YOU HAVE A VIDEO SWITCHING PROBLEM.
Jun 30, 2008 | Toshiba 32AF42 32" TV
Component video inputs 1 and 2 look very fuzzy, but DVD component doesn't, 720P
Hello, I am sorry for your issue. The audio inputs should not matter. It sounds like those inputs do have a problem. Please contact Onkyo at 800-2291687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo TX-SR304 Receiver
Fuzzy picture
You might want to try a new cable, otherwise it might be a loose jack that if your daring enough, you could fix yourself
Jan 09, 2008 | Zenith D65W25 TV
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
203 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
