Question about Kenmore 72073 Top Freezer Refrigerator
Kenmore Fridge not working
I have a 5-6 year old Kenmore top mount Fridge not working. I first noticed the freezer was not freezing things and now it is totally not working. I have removed the back of the unit and cleaned the coils and everything else. I removed that black plug being held on by a metal clip and shook it and it does not rattle. The fan nor the compressor will not run...Any ideas
  • Anonymous Feb 17, 2008
    kenmore 150206
  • Anonymous Feb 25, 2008
    Have refrig only 13 months and freezer won't cool. Tapped on shroud over fan inside freezer & it kicks on temporarily. Any ideas?
  • 247 Answers
Worth checking if it's a starter problem before you do anything else. Leave the thing switched off for a couple of hours, then try and create a little hush around you while you switch the freezer back on. If you're really lucky, this may get you going again (some freezers can get into a complete mess if the power goes off for just a second or so at the wrong moment). If the compressor doesn't start, leave it switched on and listen carefully for a minute or two. A distinct "pdoink" sound some time after power is applied points towards the starter (which is usually under a plastic cover mounted on the compressor body). Replacing this isn't difficult and is usually cheap enough to be worth a gamble (but read the last paragraph, as there's a substantial risk it won't work). If there are no suspicious sounds (and maybe before you go spending money on a starter even if there are suspicious sounds), use a multimeter to test (carefully) whether electricity is getting to the starter. If it isn't, then find out whereabouts the power supply is getting interrupted. If power is getting as far as the starter, and the compressor is still not running even with a new starter, then you're starting to get into "beyond economic repair" territory. A.
Posted on Feb 26, 2007
We have a Kenmore top freezer (no ice maker) refridgerator less than a year old. The frige part is warm while the freezer is frozen. Turns out the vents on the top of the fridge were clogged w ice. We...
Very likely the vents are freezing due to the defrost drain is blocked so instead of the water from the defrost draining into the pan on the bottom as its supposed to its pooling in the freezer and freezing over the air vents.
This tip i wrote will help ya to clear the drain. http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Kenmore Refrigerators
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Fridge and freezer are not cooling well
hi.
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
thank u
rate me!!
Jul 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer freezes, fridge below will not cool
if your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Nov 17, 2008 | Kenmore Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Kenmore 72073 Top Freezer Refrigerator Logo
107 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
