Question about Cell Phones
Phone disconnects shortly after dialing.  says" conditional forwarding"  then "call ended"
  • pulkitsaxena Jan 25, 2009
    my phone is from abroad. i am in india i have decoded the country code.mobile is working properly also selecting network of india but when i am making call it says '
    'call ended''
    Problem Solver:
  • 16 Answers
Call you cellular provider and sk for codes to disable conditional call forwarding, it should be something like *772
Posted on Dec 09, 2008
In normal condition phone continuously ringing what do
There could have been a short or ground in the telephone line (Tip and Ring). Please check the connection of the Tel line cord in the junction box. If your Tel line consist of 3 wires, disconnect all three wires, lift the handset, connect only 2 wires going to Exch Line or Trunk line (Local Tel Company) until you hear the dial tone. Leave the other wire disconnected.
This helped me isolate the problem, I hope this applies to you.
Best regards.
Sep 02, 2015 | Lands Phones
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
How do I forward my phone (DKT-2020-SD) to voicemail?
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Dec 08, 2010 | Toshiba DKT-2020-SD telephone
How to forward calls to another extension with panasonic kx-t7630
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
I need to retrieve my home phone messages from cell phone
2. Press *7 2.
In some areas you must use 72#
3. At the tone, dial the telephone number where you want your calls transferred.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
My phone dials out the last number when opened.......
hi,
you could try some things such as,
- Restoring the factory settings of the phone.
- Get your phone to your salesman and ask for a software update.
It will not cost much and would definately fix your phone.
Looking forward to hearing from you regarding further assistance!
Aug 12, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
753 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
