Question about Panasonic CT-27SC13 27" TV
On and off button wont work
I want to know how to take the cover off the tv so i can replace the on and off buttons
  • 60 Answers
First you need to unplug your tv then turn your tv with back side to you use one screwdriver to remove the screwed then be careful and take out the button and replace him put back your cover and that is
Posted on Dec 10, 2008
Anyone know why my LG tv has the input menu stuck on the screen. it is not the remote and the buttons are not stuck.
Disconnect the television overnight. Remove the batteries from the remote as well. Tomorrow, put new batteries in the remote and plug the television in.
Nov 04, 2017 | LG Televison & Video
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
My son is in Stanley Correctional. He has a 13" Hiteker flat screen TV. The button for changing stations won't work, so he's stuck on one channel. How to fix this problem. Thank u.
hi the problem with your tv is with in button key controller board, here are the ways on how are you going to fix the problem.
  • open the back cover of your tv with the use of philip screw driver to gain access the button controller.
  • remove the connector and then detached the controller board, spray the channel up/down button with a electronic contact cleaner to have good contact.
  • if the buttons are worn out you can replace only the buttons just buy at any electronics store, you can also buy or replace the whole button key controller if you want. there are sites in an internet which provide button key controller for tv like for example you can inquire here.
  • now after you replace with new button controller reinstall the connector fix it not to loose and then placed the back cover of the tv unit and screw it.
  • plug the power cord then turn on the unit. good luck i hope it will help you.
Jun 10, 2011 | Televison & Video
Wont Turn on
we need to trace where that parts not working, first we need to open back cover check if power come to power supply section. let me inform for it.
Apr 14, 2010 | LG 32LG30 32 in. LCD HDTV
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
I have a Panasonic pt-52lcx65-k. I thought the lamp was gone so i replaced it. Now the tv wont come on at all. Just a orange light flashing. I tried to reset it by holding the volume button and the pip...
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Dec 19, 2009 | Panasonic PT-52LCX65 44" HDTV
My toshiba tv is going through all the menu options and wont stop
you have it in the demo mode go into the menu and turn auto demo off.
Aug 07, 2009 | Televison & Video
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
Sanyo tv wont stay on
The problem of your TV is the power switch, and best solution for this is replacement with a good one.
Warning: The next procedure must be done by an expert to avoid risk.
1.Open the the back cover of the TV and detached the board.
2.Try to see any broken solder or cut PCB lay-out on the board.
3.Get a continuity check to the switch.If the switch is defective replace it with a good one.
Jul 13, 2009 | Sanyo HT32744 32" TV
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Panasonic CT-27SC13 27" TV Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
