Question about SanDisk Sansa e250 MP3 Player
Frezze and the screen is black and the ble rotator light is on
First i was freezeing after it said refresh database the i did these steps . 1.Switch the player's hold button on. Hold down the record button and power up at the same time. This will bring you into recovery mode. Now plug your player into the computer. 2. Go to http://www.sandisk.com/assets/file/downl... and download that program. Run the program and select yes to format and install the new firmware. 3. Unplug the player and wait for it to reset. This will install the old firmware version, so once it is working again, but it never worked after that the screen just went black and the ble rotator light turned on and even wen i reset it it cums bak up lik that it wont even let mi put it on recovery mode agiain either what shud i do :(
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Sansa e270 freeze if switch on,it indicates,REFRESHING DATABASE"
Having gone over a month with no response, I assume the reset solved the problem.
Jul 08, 2010 | SanDisk Sansa e250 MP3 Player
My sansa player turns on and freezes on the Refresh Database screen. The screen then fades and eventually turns black. My computer won't recognize the player either.
STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and install the Sansa Firmware Updater
this is for mac os version.
Feb 25, 2010 | SanDisk Sansa e250 MP3 Player
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
No picture on screen
Hi . This can probably solve your problem:
Follow the steps
01. Sansa player freezes on the “Refreshing Database” screen STEP 1 – Reset the device
STEP 2 – Download and Install the Sansa Firmware Updater.
If this article did not resolve your issue, please contact us at support@sansa.com.
Oct 30, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 problem
my sansadiske250 showing refreshdatabase
Apr 17, 2008 | SanDisk Sansa e260 MP3 Player
My e200 mp3 sansa player can get refresh database
Hey Do the recovery Turn ur mp3 off lock it and hold rec and on it wiil have u plug in the usb cord and leave it there for 5 min And unlock then it will turn back on its self
Aug 19, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
