Question about Dell E176FP 17" LCD Monitor
Dell E176FP 17" LCD problem, screen periodically cycling colors..
Our Dell E176FP 17" LCD monitor works for a time after the computer is powered up, then turns dark, and begins to cycle through colors - red, green, blue, then black, then colors again. At first I thought it was a default screen saver, but changing those settings didn't fix the problem - and it doesn't go away when we touch the mouse, use keyboard keys, or otherwise do the things that would bring it out of screen saver, hibernation, etc.
The only thing that fixes it temporarily is to unplug the power for a bit - it won't power off with the power button - and then plug it back in, but this problem returns some time later. As far as we can tell, we are still able to use the computer, we just can't see the desktop or program - for instance we can exit out of programs using keystrokes, and shut it down using the windows key, but only if we know which keys to use to get it to shut down.
Is the monitor dying, or is this some other problem? We had thought it might be the video card, and needed to upgrade in any case, so we did. At first we thought this had fixed the problem, as it did not reoccur for some time after this, but then began again. Could it be a problem with the motherboard?
Thanks in advance.
2 Suggested Answers
  • 6 Answers
SOURCE: My Dell E176FP 17
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Posted on Apr 24, 2010
HOW TO ADJUST BRIGHTNESS E176FP DELL MONITOR
Just press the menu button at the bottom the screen bezel and then select brightness. You can decrease and increase the brightness by pressing the plus or minus button .
Hope this helps
Thanks
Dennis
Oct 27, 2011 | Dell E176FP 17" LCD Monitor
How to get rid padlock Dell E176FP 17" LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
Monitor display on Dell E176FP
You may loose connections at the end of the VGA cable, or video card not seated tightly. I would check that first.
Apr 23, 2010 | Dell E176FP 17" LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Dell E176FP Monitor Stuck in diagnostic mode??
See if the set has some sort of reset button. If none do a hard reset on monitor to hopefully clear the cobwebs in monitor electronics and see what happens.
Mar 12, 2017 | Dell E176FP 17" LCD Monitor
My monitor (Dell, 17", flat screen, about 2 years old)has recently started changing colors spontaneously. This happens whether the computer is on or not. It cycles through a bright yellow screen to bight...
they can do this if the monitor is shorting its self, might just need a dust out with a paint brush, while you have the back of the monitor check the main-av-power board and look for signs of weak capacitors this can also cause the same faults.
May 19, 2017 | Dell E176FP 17" LCD Monitor
Problems with Dell E176FP 17" LCD Monitor?
Kindly disconnect the monitor from the computer and power it on , if the screen is still blurry on the self test feature check , the monitor is bad.
You can press the menu button on the monitor and select Restore to Factory setting or Factory reset option. If the problem persists you can call LCD repair
http://www.lcdrepair.us/
Monday to Friday: 8:30 am to 4:30 pm
Central Standard Time
Phone :
469-521-7517
If you have purchased,the dell monitor seprately from the computer, it carries a three year replacement warranty.
Thanks
proton
Nov 21, 2008 | Dell E176FP 17" LCD Monitor
Monitor problem
Try unplugging the video cord from the computer.
If it does the same thing then it is not detecting your cord.
If so, try a new cord.
What does it say on the screen if the above does not fix it.
Feb 23, 2008 | Dell E176FP 17" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
465 people viewed this question
Alun Cox
