Question about Maytag Washing Machines
A burning smell while Maytag neptune was washing.
My wife thinks it could be a belt. I think it smelled of buring plastic and seemed to be coming from the control unit.
  • 79 Answers
Shut down and unplug machine a.s.a.p.! It could be your door latch wax motor failing which will burn the R11 (resistor) and Q6 (triac) on the machine control board. You did not mention which Neptune you had... If it is a MAH3000, MAH4000, MAH5500A or a 2000 stacker and you have not replaced the door latch wax motor (12002535) then your time is up. See for details for the repair kit or you can purchase a new control board and 12002535 wax motor and be up running quickly before the clothes pile get too high.
It could be the seal and/or bearings if the machine is starting to get loud in the high speed spin cycle. If so, See for the seal and bearing kit plus they offer a special Neptune bearing tool for rent called the tony tool. A Maytag technician will want to charge you $900 to replace the whole outer tub? Why replace it when just the bearings and seal kit need changed?
Posted on Dec 10, 2008
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My neptune washer smells like rubber burning when i wash clothes
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number
Jun 22, 2017 | Maytag Washing Machines
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Sep 18, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Open Questions:
Washing Machines Logo
173 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
