Question about HP Serial adapter (17302A)
Hp 1730 monitor will not turn on. The power light on the front of the monitor blinks. Screen is black looks to be off. when i push the power button nothing happens.
  • floydgator1 Dec 21, 2008
    I have the same problem hooking the monitor to my old gateway. Even after loading the drivers.
  • Wimpie Hall
    Wimpie Hall May 11, 2010
    Hi xjcrawler1
    Do you have the fasility to test monitor on another PC? Could be PC related.
  • 105 Answers
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Posted on May 09, 2009
  • 238 Answers
Try to use Graphics card. Insert your monitor cable to it. Make sure you have a Graphics card slot on your motherboard. If there's still no display on the screen, then it is on your motherboard problem.
Posted on Dec 24, 2008
How do I retrieve photos on my hp pavilion 325c? When I try to turn the desktop on a light blink under the power button
The light blinking under the power button is Hard Drive activity which is normal. Do you have the monitor plugged in and switched on?
Nov 01, 2017 | HP Computers & Internet
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href=""></a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
My hp 1730 lcd screen is making a humming sound which seems to get lower when i turn down its brightness but doesnt go away any suggestions?
That sounds like the inverter that powers the back-light. Unless it's really annoying I would just live with it. It's probably more expensive to repair than to buy a new similar sized screen.
Oct 08, 2009 | HP 1730 LCD Monitor
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
HP Serial adapter (17302A) Logo
1,178 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
