Question about HP w17e Monitor
LCD monitor comes on for about 10 seconds then goes off
My HP monitor comes on and shows a perfect screen for about 10 seconds then goes off.. turn the power off and turn it back on, same thing..
  • the_harvill4 May 11, 2009
    My monitor does the same thing...comes on perfect for a couple seconds then goes dark, power light stays on.
  • 54 Answers
It sounds like the power supply board on the monitor may be faulty (that or the backlight).
You could test it on another computer to see if does the same thing (or another monitor on your computer).
If the same problem occurs on this LCD you'll either need to get it repaired under warranty, or pay for it to be repaired. Or just throw it out.
Posted on Dec 09, 2008
When I open HP MY DISPLAY software it doesn't work. It looks full black. There is no menu or option. It shows blank. So I can't tune display color or any other things. I uninstalled it. Then I...
HP W1707 LCD Monitor circa 2008 old. 10 years old NOW.
No PC stated or any OS at all. windows what?
connected to what? it must be connected to a working PC
or the monitor is useless as 3rd shoe.
i can only be 2 things, PC or screen bad.
  1. the test is child easy test the monitor on another PC.
  2. or test the dead PC on another good monitor.
the monitor has no software ever.
only the PC side does for the PCs video chip GPU driver.
but the PC always has one, even if, poor quality resolution.
Toss magic coin land on bad w1707
The screen, can fail for many reasons lets say it fails on a good PC. known good.
these old monitors have CCFL lamps that love to fail inside.
It has no LED back lamps , before 2010. it haS CCFL lamps.
The monitor all by its self, pc disconnected.
you power it on and it shows logo, HP or Compaq
then for seconds turned on the menu may work.'
if you see nothing the CCLF are dead.
The menu button works only with good running PC. but
might work for 1 second.
some do others dont but only for seconds does the OSD work
lacking a good PC connected.
the OSD is the menu from the monitor brain inside
the button is called select or menu.
PC turned off and Monitor now turned on the screen shows.
if the PC is dead the Monitors brain then shows.
NO SIGNAL , or NO sync.
or if PC is set up wrong the monitors shows, OUT OF RANGE.
CCFL love to fail.
the lamps turn yellow, blink or go DEAD.
as can the HV inverter seen here.
http://www.pcdied.com/monitors.html#Inverters-monitors
PAR:
i one uses the monitor 10 hours a day
on the 5th year, the CCFL goes dead. that is there normal life span.
Dec 27, 2017 | HP W1707 LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Screen goes black after 5 to 10 minutes of operation. Comes back on for seconds if monitor is turned off then back on
there is a screen light board defective as inverter board. there are on the market, some inverter boards available to LCD Monitor, Check for diemen Company on this site: http://www.hrdiemen.es/products/esp/index_esp.php
Dec 23, 2009 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Screen shows for 2 seconds, then black, power button still on
You could have an inverter problem or a faulty CCFL lamp/s.
For service, parts and DIY info I found LCD Parts helpful, use this link to get to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | HP f2105 21" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
HP w17e Monitor Logo
419 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
