Question about Canon PIXMA iP1600 Printer
I loaded the black ink like I have done so many times before, but a window is coming up saying it does not recognize my color catridge and will not print. I dont even have a color cartridge in the printer.
  • jnbanc Dec 09, 2008
    printer was working before without the color cartridge.
  • 54 Answers
Some printers will not print while missing either of the cartridges, was the printer working without the colour cartridge before?
Try inserting a colour cartridge and see if that helps.
Posted on Dec 09, 2008
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Black ink cartridge
you should be able to disable black ink printing by going to the printer preferences selection through your Windows OS printer & faxes function.
Alternatively, if you have loaded the printer monitoring CD that came with your printer then the ink status function should prompt you to disable the black cartridge if it detected it has run out.
May 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have refilled Black ink catridge and colour ink catridges. Black ink volume is not showing and printer is not printing. Colour ink catridge volume is recoginised. May I know what is the problome? Thank...
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 15, 2010 | Epson Stylus C60 InkJet Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
My hp 1310 says no colur ink catridge found.
No
some model hp deskjet all in one used duel cartrdge because it is a color popier
Jun 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Have a Canon PIXMA MP150, just recently replaced the Black ink cartridge. When I make copies I will press the black ink button for my black copies but the only light that come on is the color ink button. ...
the problem occurs mainly due to following reasons
clogged catridge head
*clean it using ammonia solvent
bad contact of catridge terminals
*clean the contacts of both catridge and catridge holder
Apr 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't print black ink
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to Print i am sure it should work..........
Good Luck............
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
117 people viewed this question
old marine
old marine
