Question about HP Photosmart C6180 All-In-One InkJet Printer
C7280 hp all in one has failed the fax hardware test
My device test keeps failing and am not sure what to do next.........help
first message: device has failed the fax hardware test.
Second message: an active phone line was not detected.
while i do have an active phone line am perplexed!
  • gmendez18 Dec 09, 2008
    anyone out who can help solve this problem.......need help. thanks.
I uninstalled and installed again and that seemed to have fixed the problem.
Posted on Dec 09, 2008
Error on hp j4680 image on fax send report is set to on
Sir/Madam
Solution one: Print a fax test
1.Make sure the product is turned on and correctly connected to the telephone jack.
2.Make sure that there is plain white paper in the input tray.
3.On the product control panel, press the Setup button ( ).
4.Press the right arrow ( ) to select Tools , and then press OK .
5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
6.Review the results of the test.
·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes.
·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution.
7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution.
In case You Still facing Problem The Visit official HP Printer website Below URL Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888
OR
If you Still having Problem then follow Us On:
HP Printer Support
Feb 12, 2014 | HP J4680 Office Jet All-In-One Printer
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
Can't use fax on HP C7280
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | HP Photosmart C7280 Laser Printer
Fax Failed - Test Failed- Hardware Failure
had a lightning storm since? if so the modem in it may have been hit. i recommend pluging all devices into a electrical strip/surge strip to help prevent that. could be something else, but get back to us if you had no lightning around since it worked.
Aug 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
11 printer not found during laptop IPL for HP C7280
CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL:
DEVICE MANAGE
NETWORKING AND SHARING
PROBLEMS AND REPORTS
SYNC CENTER IF IT IS PLUG AND PLAY DEVICE
WINDOWS DEFENDER
WINDOWS FIREWALL
SECURITY CENTER
AUTOPLAY
MAKE SURE THERE ARE NO YELLOW, RED, MARKS, TROUBLESHOOT ALL UNKNOWN MARKS YOU WANT ONLY GREEN MARKS,THAT SAYS EVERYTHING IS CONNECTED RIGHT AND COMMUNICATING WITH EACH OTHER, DRIVERS ARE OKAY BUT MAYNOT BE UP TO DATE.
TO FIND MOST UPDATED SOFTWARE ON THE COMPUTER WWW.DRIVERDETECTIVE.COM PROGRAM CALLED DRIVERDETECTIVE_1.EXE
WILL LIST ALL DRIVERS IN YOU COMPUTER SYSTEM AND MAKE SURE THEY ARE UP TO DATE AND ASK IF IT IS OKAY TO UPDATE THE SYSTEMS SOFTWARE ALWAYS YES OR OKAY.
Mar 14, 2009 | HP Photosmart C7280 Laser Printer
I can send a fax, make copies, but cannot receive a fax on my HPL7590. Help
hi tbacsa02,
this was a solution i posted earlier with someone that has the same problem like yours.
follow this few steps;
first can you try this;
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test does the following:
• Tests the fax hardware
• Verifies the correct type of phone cord is connected to the device
• Checks that the phone cord is plugged into the correct port
• Checks for a dial tone
• Checks for an active phone line
• Tests the status of your phone line connection
The device prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test.
To test fax setup
1. Set up the device for faxing according to your particular home or office setup instructions.
2. Make sure the ink cartridges are installed, and that full-size paper is loaded in the main tray before starting the test.
3. From the device control panel, press Setup.
4. Press right arrow to select Tools, and then press OK.
5. Press right arrow to select Run Fax Test, and then press OK.
The device displays the status of the test on the display and prints a report.
6. Review the report.
• If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause problems faxing.
let me know.
Jan 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Whats up with fax fail test
Check to see if your phone operates on the same jack the printer is connected to. Is comcast your telephone service or internet provider? You need to have a landline phone service or VOIP for a fax to work.
Dec 28, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
550 people viewed this question
Seeker5211
Seeker5211
