Question about Kodak EasyShare C330 Digital Camera
Camera wont turn on
Kodak easyshare c33o
  • sarahrn1978 Dec 28, 2008
    MY KODAK EASY SHARE C330 CAMERA WILL NOT COME ON WHEN POWER IS TURNED ON THE PROBLEM FIRST BEGAN WITH THE LENS NOT COMING OUT CORRECTLY WHEN TAKING PHOTOS ALSO AFTER THE CAMERA IS TURNED OFF THE LENS WILL NOT GO BACK IN ALL THE WAY NOW THE POWER WILL NOT COME ON AT ALL
  • sndadams Dec 29, 2008
    I have the same problem exactly all of a sudden.
    Could it be thr camera is full? sndadams@yahoo.com
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
My Kodak EasyShare P850 Digital Camera won't turn on
Spray a littlebit of WD40 or contact spray round the powerswitch, after removing the batterie and work the switch a number of times.
Feb 24, 2011 | Kodak EasyShare P850 Digital Camera
Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
Jul 23, 2010 | Kodak EasyShare M853 Digital Camera
The lens thing gets stuck wont go in or out and camera shuts down
I may be able to help with your Kodak EasyShare Z740 with a stuck lens.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 05, 2010 | Kodak EasyShare Z740 Digital Camera
Camara wont stay turned on
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Apr 15, 2010 | Kodak EasyShare Z740 Digital Camera
On a kodak c33o camera i get error code e 00100 when i try to format memory card
Hi there.
If the SD card is over 1GB then the camera does not support it.
The Kodak Website States that your Camera does NOT Support 2 Gig SD Cards...
However, there is a Firmware Upgrade Located at the Link Below that is said to Help Resolve this Issue...
Kodak Firmware Upgrade Page...
Thanks for choosing FixYa!!
Jun 09, 2009 | Kodak EasyShare C330 Digital Camera
My kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Apr 03, 2009 | Kodak Easyshare C813 Digital Camera
TECHNICAL SUPPORT AND ADVICE FOR MY KODAK EASYSHARE C33O
Bring your camera to the nearest service center. maybe program errors on it.
Dec 26, 2007 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
205 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
