Question about Kenmore 13863 Stainless Steel Dishwasher
Kenmore Elite Dishwasher 13863 will not start
We just bought & installed it yesterday. It will not do anything-- it acts as if it does not have any power at all. The circuit breaker is fine. Any ideas?
  • Patricia Thuringer Feb 25, 2007
    I don't think that is the problem but am wondering if there is a fuse inside the dishwashwer that might be blown.
  • 72 Answers
I would check the door interlock, an electrical switch that prevents the dishwasher from running whenever the door is open. Maybe a loose wire there.
Posted on Feb 25, 2007
  • Ican Surf
    Ican Surf Feb 26, 2007
    Look for an electrical schematic diagram stored inside or under the unit, or with the owner's manual. Look for fuses or other protective devices.. or anything switchable or could be set in the off position. also look for loose wires if you can get to them.
SOURCE:
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Kenmore Elite dishwasher: not doing anything.
turn off power an back on / if no change remove the toe panel and the tech sheet will be there . it will tell you what the code is and how to correct most .. mm hope this helped. pls leav feed back.
Dec 07, 2009 | Dryers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Apr 21, 2008 | Kenmore 15919 Built-in Dishwasher
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
164 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
