Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Envision EN8500 inverter
Hello. I have the above monitor and was told today that I need a new inverter. When trying to come on, the monitor will flash on & off very quickly and do this over and over. Where can I get this part and is this fairly EZ to do myself if I know my way around a screwdriver?
Thank you in advance!
  • Russell Benson
    Russell Benson Dec 10, 2008
    Fanicate, Thanks for the reply. I was able to get the inverter out very easily but I am having trouble finding that same part. There are lots of places that sell inverters but I cannot for the life of me find this one. The part number is 715L1017-1A. I have emailed Envision twice but have not yet gotten a reply and have searched high and low on the web. If anyone has any idea where one can be had, I would be grateful knowing. THanks!
  • 60 Answers
No you cant change it yourself because there need some tehnical knowlege so better you buy new one
Posted on Dec 10, 2008
I have a n envision 22" flat panel TV purchased
I don't think there is still warranty for this TV. Usually, warranty last for 1 to 2 years... In summary there is not warranty for this TV, it must have expired.
To further confirm, check the receipt of purchase. The warranty duration should be stated there.
I hope you understand the above....
Good luck.
Mar 19, 2011 | Envision G22LWK 22" LCD Monitor
My monitor will not work it is flashing a green light on the led indicator
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ENVISION monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Envision EN7410 17" LCD Monitor
GReen flashing light and the monitor will not come on???
Please verify that it does the same with other PC.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Envision monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 27, 2010 | MPC Computers Envision EN 7100s 17 in....
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
We have an Envision 9410e 19" LCD monitor which is about 4 years old. Recently it has started being very slow to start up, especially in the morning after the system is not in use all night. The screen...
cmgusa, Reconnect 9410e to original PC. Please note if same symptom occurs again. This sounds like an intermittant or failed solder connection of some component on the inverter/smps power supply board. Have you tried the FLASHLIGHT test when the monitor goes to a BLACK screen? You did not state the approx # of hrs of use this unit has on it. The Flashing you describe is most likely the cold-cathode-fluorescent-tubes trying to start-up. If they don't light then you get a black screen. They (CCFT) get their voltage from the inverter section of the power supply. But anyway... Your options as a consumer/user are as follows. Check with Envision to see if they have a swapout program... you send them your 9410e +$50-$90 and they send you a REFURBISHED 9410e with 30-90 day warranty. or Find local TECH (TV-Monitor) who knows forward and backwards all there is to know about repair of LCD monitors. There are some very good tech's right here on fixya that could do the repair and not rip you off. Last but not least is try to effect repair yourself. If this last option is of intrest get back to me only after doing web search of monitor disassembly video clips on youtube and doing search for things like bad caps or recapping and inverter repair + have a minimal understanding of how a SMPS/inverter powersupply functions. I'm louie12fix on fixya or lmistyrel @aol.com Bye for now.
Sep 21, 2009 | Envision 19" Widescreen Flat Panel LCD...
My Envision 9410 Monitor flashes on and off. You see the picture fine, but then it goes to a black screen and then back to seeing desktop. The power light goes on and off while this is happening. Is...
Its either going to be the inverter or the lcd going back and it can't keep the screen lit.
Also I've seen it where the capacitors on the power board go puffy and they need to be replaced.
It will be one of those three things.
May 15, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Envision color monitor, Model EN910e
Hi..there! Barb,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it. Have a nice day!
Oct 22, 2008 | Envision EN-7220 17" Flat Panel LCD...
THE SCREEN IS BLACK ON MY SCEPTRE 17" X7 MONITOR. THE GREEN LIGHT IS ON AND THE SCREEN FLASHES.
Hello JELSMA3,
This means your inverter (back light) component is bad or going bad. It needs replacing. Not sure what they go for but I was told by someone they run for about $20.00 . Once your replace the inverter, your monitor will work like new again.
Good luck.
Jul 25, 2008 | Computers & Internet
H 170 L-17" monitor
If *nothing* displays on your screen, the most likely problem is your LCD Backlight Power inverter. If the backlight power inverter is bad, you can usually see some remnants of an image on the screen if you shine a light on it. If the backlight power inverter is bad, it may not be worth repairing on a 17" screen, considering the low cost for a new one.
It should be noted that Envision provides a 3-yr warranty for most LCDs, so contacting them for repair may be a good option. More information here:
http://www.envisiondisplay.com/support.asp?EPage=support&SMenu=lcdwarranty
Feb 17, 2008 | Envision H170L Monitor
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
