Question about Linksys Wireless-G Broadband Router
Can you please help me?
Hi i have a wireless-g 2.4 and i need help to set it up can you please help me
  • bassofive Dec 14, 2008
    My problem is almost the same. After going through the set-up (connecting the ethernet wire to the silver internet on the router and the second wire from the router to the computer) It says that it isn't connected correctly. then it says retry and I go over it again...
  • 60 Answers
Hi what sort of problem do you have, if you just using it without the wireless just plug all in then turn modem on then router and then your computer, if you need wireless scan for an connection and click connect (please note makesure your wireless connection is password connected to stop other using it without your permision..)
any more help please let me know always maksure that you can connect pc to modem for internet connection to make sure you can get one
Posted on Dec 09, 2008
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
I need the wpa key number
Your wireless network must be secured
You will need to check the wireless settings of
the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Mar 25, 2010 | NetGear WGT624 Wireless Router
I just need to unlock the security on my wireless netgear router
Hi my name is Eric,
I hope I can help you with your issue ,
Press the reset button on the back of your router to reset it to default
generally this works, I do not have your model # but these have a reset for this reason. the read your ,manual for the default password admin admin I think
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | NetGear WGR614 Wireless Router
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless router
Hi
router administration tool can be open through browser (Internet Explorer). you need to make sure that laptop is connected with router by direct cable or through wireless connection
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin and the password is blank (nothing). Click OK.
this will open the router administration tool.
Please vote if this solution is helpful.
Dec 31, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
Im having problems conecting my nintendo wii to my tiscali siemens gigaset se587,can you help me please as i have tried to link them both together with a wireless conection but i just get an error message?...
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck IAN.
Sep 02, 2008 | Video Game Consoles & Games
Wireless security
Hi anthony - Could you please let me know the makes and model#s of the wireless pcs your running on your network. Also what operating system they're running. I just need to know because once you set up your routers' security you'll have to set up the wireless pcs with same security or they won't have access to the network. If you already know how to do that don't worry about it. Just thought I'd help you do that too. Just make a little list with one pc a line and each ones' info. Then I'll be happy to assist you. Thanks.
Jeff
Jul 20, 2008 | Dell TrueMobile 2300 Wireless Broadband...
I need to install a new laptop to my Netgear System
Hi!
You'll need to configure the wireless settings of the laptop to work with the wireless router. These are the common settings that you'll need for it:
1. SSID (wireless signal from the router)
2. wireless security (WEP or WPA)
BTW, does the laptop detect the wireless signal being transmitted by the router?
May 28, 2008 | NetGear RANGEMAX WNR834M Router...
Linksys Wireless-G Broadband Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
