Question about Bosch Skil Drill / Driver Kit
Skil drill/driver will not run at full speed
My drill will not run at full speed 100% of the time. I will use the drill and it will run full speed and then the next time i use the drill it will run half speed. Could this be the switch?
  • fplqnewc
    fplqnewc May 11, 2010
    Yes, sounds like the switch. Is it a variable speed? Small pressure, it moves slow and max pressure it is max speed?
    I have a drill with a bad switch and it only has MAX speed. No matter how light the pressure it is full speed. I had to stop using it because I have no control of the speed.
  • transit360 May 11, 2010
    Is this after the course of a few days use? Or immediately after?
2 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: variable speed not working
The switch is bad. The part number is 2-610-998-107.
Posted on Aug 22, 2012
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
My battery will not charge
Supposedly there is , But I don't think so, There is a video on you tube that shows somebody messing with them, I think it is a bunch of ****. Is it the battery or the charger? Do you have other batteries that charge up? The life of the battery is about 1 year. I have boxes full of dead batteries, and guns and chargers. It is cheaper to buy a new gun with batteries and charger than it is to buy 2 new batteries. Check it out.
Jul 11, 2010 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 06, 2009 | Skil 6237 04 5.0 Amp 3/8 Inch Keyless...
Would like to know how to remove the battery for a recharge
there should be push buttons on either side of the base of the tools -you will have to push both in at the same time while pulling the battery out
Apr 27, 2009 | Skil 18VOLT Cordless Drill & Saw Combo Kit
I have a Skil 2362 7.2v drill that goes dead when charged
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Jan 19, 2009 | Bosch Skil Drill / Driver Kit
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Bosch Skil Drill / Driver Kit  Logo
27 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
