Question about HP Office Equipment & Supplies
C6280 always prints photo over the perforated tab line
My c5180 printer died and the software was left on my xp system. Bought a c6280 printer with a duplex unit on the backside. Installed the s/w and tried to print photos. got frustrated and deleted the "driver" for the c5180. the c5180 came with HP photosmart premier photo s/w which I like. the c6280 came with photosmart essentials 2.0.1 which i do not like. every time i print a photo on the c6280 it prints over the perforated tab line no mater how the paper is inserted into the printer tray-tab in or out. i disabled the duplexerprinter properties device settings. i tried specifying the paper has a tab, and just plain 4x6 paper.
HELP!
After 3.5 hours with HP controlling my computer, I finally asked if thec6280 has "auto sense" which determines whether the paper in upsidedown or rightside up. The c6280 does not have "auto sense". Maybe thatis the problem. Each time I print on tabbed photo paper, the printeralways leaves a half inch of white at one end of the paper and alwaysprints over the tab, even when the paper is inserted tab first or tablast into printer.
Anyhow, I gave up trying to print tabbed photo paperon the c6280. HP technical support has no clue what is wrong ifanything. If I print on plain 4x6 inch photo paper the print is just asI like. If I print on the tabbed photo paper with the tab removed andthe "tab" end entering last, the printer leaves a half inch of white atthe end of the paper that exits first. If I print on the tabbed photopaper with the tab removed and the "tab" end entering first, theprinter prints just as I like.
The c6280 has "paper type mismatch"issues with the tabbed photo paper with the tab removed. The c6280reads the markings on the back of the tabbed paper and un-tabbed photopaper. The problem is in how the c6280 reads the markings on tabbedphoto paper when the tab is attached and when the tab is removed.
Un-tabbed HP photo paper is hard to find in stores.
Well, that is mystory and I'm sticking to it.
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: Trying to print a 4
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
Posted on Aug 02, 2011
HP C6280: front panel buttons doesn't works
Sounds like a classic "printer driver compatibility" issue. The following page has the 64 bit driver for the 6200 series. I suspect you are using an earlier 32 bit driver which is why it performs as it does on your Windows XP 32 bit system. Windows 7 Home Premium is a 64 bit system even though it does offer an XP compatibility feature. You would not put the 64 bit driver upon the XP system. The first link below is to the 64 bit driver. The second link refers to support matters and Windows 10.
HP Customer Support Software and Driver Downloads
https://support.hp.com/us-en/document/bph07165#AbT3
Sep 03, 2017 | Office Equipment & Supplies
Will not print from computer, always ask to please insert a memory card
Check yur printer software on the system. It may be corrupted . check it and reinstall the software
Thank u
Please rate me as it wil cost u just one click
Oct 23, 2009 | HP Photosmart C6280 Printer
C5180 won't print in black and white only
I do not have this model printer or computer, but I thought I would offer that most printer set-up dialog boxes from the program you are printing from, will let you select mono. I'm somewhat familiar with this because I use CAD software and though I draw multi color lines, I want only to print black-line.
I hope this helps... Good luck!
Sep 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
Jun 23, 2009 | HP Photosmart C6280 Printer
My printer will not print
You do it through the software on your PC. HP has user software that you installed when you set up the printer. There is usually a setting for color/BW there. Otherwise use the printer properties settings.
Dec 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6280 HP all in one
PDF documents can be protected against printing...
Oct 18, 2008 | HP Pavilion dv9000z Notebook
166 people viewed this question
Ben Johnson
