Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kv35s26 (August 1997) no video, only audio
The picture on my Sony Trinitron (model KV35S26, August 1997) went out.
The audio works fine and the “stand by/timer” red light continuously blinks. When I turn the TV on, I don’t hear that “thump” noise that I usually hear.
Any suggestions would be appreciated. I wanted to troubleshoot the problem myself. Were can I find a troubleshooting manual to get started?
Thanks,
Jim
manufactured in August 1997 has audio but no video my tv is a 27 in. i turned it off and tried to turn it on about 7 hours later and the picture slowly went to the top of the screen and vanished after turning it off and back on it came on a couple of times for about 2 min. at the most and now i get nothing i really dont know the model #
3 Suggested Answers
  • 905 Answers
SOURCE: sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Posted on Oct 31, 2008
  • 4234 Answers
SOURCE: Sony kv35s26 TV: no picture, audio works, stanby light blinks.
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Thanks,
Dan
Posted on Jan 19, 2009
Sony trinitron kv35s26 no high voltage.
Continuous blinking of standby light to Sony TVs indicates a fault with its II2C bus. Your set need an through checkup, which can only be done by any experienced service technician. Anyway, try the site linked here, and see is there any details which could help you. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 21, 2012 | Televison & Video
Tube heater on a sony trinitron not working
They will usually be marked on the crt board socket on foil side with H, and another way to find them is follow them back to the high voltage transformer where the go---you will read a short and that is normal across them--I would bet if you locate you will find at the high voltage transformer or between it and the crt board broken connections or a open resistor----less than 20 of the connections between flyback (the transformer) and crt board---FYI the voltage across the two should be 6.3 volts AC.
You can trace it that way also if you locate the source. Worst case is no voltage at the source which would mean the transformer is bad but that is rare.
Dec 16, 2012 | Televison & Video
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My triniton wega tv 32 inch flashes 5 times and i lose the picture then it comes back on lasts awhile then lose the picture again flashes 5 times again over and over
you can ensure the connection and Heater's voltage, start from Flyback transformer ( Heater Pin) to Heater of the CRT tube, whether exist and normal ( Include : check Resistor in Heater area), perhaps there is lost connection for a while and connect gain. There should be 5 Volt AC available. otherwise check the socket of CRT Tube, unplug and clean it. If there is any question you can ask me and clarification with detail result from my solution.
Aug 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Thanks,
Dan
Jan 19, 2009 | Sony KV-32FS13 TV
Sony
Model:kv32s45
Chassis:AA2d
Comments:
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony Trinitron KV-29RS36C
more than likely there are numerus bad solder connections in the set. give the set a light tap on the sides and see if the picture returns, if it does locate and repair bad solder connections. most of them may be found on the G board. the A board may have several as well. in the past I have seen the delay line have the bad solder which drops the picture out.
Jan 12, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Kv35s26 Sony Television Trinitron
1) Solder pins of vertical output IC........if that doesn't do it.....
2) probable bad CRT = not worth pursuing..................T.
Please rate this solution.....................
Apr 24, 2007 | Sony KV-27V22 TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
