Question about Mitsubishi DD-6030 DVD Player
Some DVD's load, others not
Problem just started with loading a dvd. Some dvd's load and play with no problem while others just spin (no unusual noise) with the LOADING indicator highlighted on the front. After a minute or so, the spin stops and the dvd light comes on on the front panel. I checked to insure that parental guidance was off thniking possibly that this may have had something to do with the random loads an also have blown air into the unit hoping to remove any dust. Neither resolved the problem. Since this only happens on certain dvd's, I have run out of options thinking that some of the newer dvd's have a configuration unreadble by the unit. The unit was purchased in 2002. Any help or guidance will greatly be appreciated. Thanks!!!
  • 2 more comments
  • Don Paich Mar 17, 2007
    I've noticed that I only have the problem with dvds produced by Sony; Marie Antoinette, Stranger than Fiction; The Holiday; Casino Royal. No problems with other producers.
  • Don Paich Apr 07, 2007
    The problem only occurs with DVD's produced by Sony. It is my understanding that Sony is pushing the limits on the DVD and the older players are not able to read them. Only solution is to replace the DVD player.
Block Buster needs to post a disclaimer in their stores stating this problem. It is a crap shoot for people with older DVD players as to whether or not your player will read the disc.
Posted on Apr 07, 2007
    Guru:
  • 104 Answers
Does the DVD that are not loaded are original DVD? If they are not maybe your DVD doesnt know to read does new formats. DVD players become old very fast since every few monthes there are new DVD formats like: xVid, Divx, new and etc.
Posted on Mar 14, 2007
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Some normal DVD's will not play--as if not loaded.
try using a lens cleaner.....normally its a lens issue....should work better after cleaning...
May 17, 2009 | Sony SLV-D300P DVD Player/VCR
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Mitsubishi DD-6030 DVD Player Logo
307 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
