Question about Passport 8500 Radar Detector
Broken windshield mount
I have a passport 8500x50, the windshield mount broke, i've opened it and used electrical tape to secure the mount back onto the top inside part of the radar and am now unsure if this has caused the radar to be less sensitive than usual. Everything seems to be functioning fine, but i would rather not risk it.
    Problem Solver:
  • 6 Answers
The same has happened to me. Instead of monkeying with it i got two pieces of velcro. Put one on the top of the dashboard and the other on the bottom of the radar. Dashboards are usually highest over the instrument cluster so I mounted mine just to the right of that giving me a good height like when on the windshield, its out of your way, and still near the cig lighter. Mine works great in that position, I have not noticed any difference in function and it still saves me. ha!
Posted on Dec 09, 2008
Both back doors are stuck. My window is broke it's cold in Detroit, can anyone help? The shop want $100
How to drill open a honda door that's stuck or won't open (no ...
? 0:19
www.youtube.com/watch?v=xHX6Up7HCfs
Jul 2, 2006 - Uploaded by SadieSummer How to drill open a honda door that's stuck or won't open (no real info on .... How To Install Replace Broken Rear Outside DoorHandle 1996-00 ...
How To Install Replace Fix Broken Rear Outside Door ...
? 9:52
https://www.youtube.com/watch?v=bUV6BZfVxDY
Jun 15, 2011 - Uploaded by 1A Auto Parts
How to Open a Honda Door that's STUCK! ... How To Install Replace Broken Rear Outside Door Handle 1996-00 Honda Civic - Duration: 5:47.
Honda Passport driver door lock stuck Questions & Answers ...
www.fixya.com > ... > driver door lock stuck > Cars & Trucks > Honda
Honda Passport cars & trucks driver door lock stuck questions and answers. Ask your ... 1996 honda passport defrost has stopped working ... dash vent ... Back seat doorsdo not open ... stuck. Any ideas of how to get them to open? It seems that ...
Oct 29, 2015 | 1996 Honda Passport
How do I dismantle and reinstall a front wiper motor on a 2000 Kia Sportage?
Wiper Motor
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the wiper motor electrical connector.
  3. Remove the four mounting bolts securing the motor to the firewall.
  4. Using a suitable prybar, carefully separate the wiper motor from the wiper linkage and remove the motor.
To install:
  1. Attach the wiper motor ball joint to the wiper linkage.
  2. Position the motor on the firewall and secure the motor with the four mounting bolts. Tighten the mounting bolts to 75 ft. lbs. (102 Nm).
  3. Connect the electrical connector.
Nov 25, 2010 | 2000 Kia Sportage
My rear view mirror broke while i was adjusting it to see my son in the back seat, it broke the plastic and i used a bonding glue that the nam gave me at the hardware store I got it on on but when i went...
Use a razor blade scraper.These work the best for removing the glue.Be very careful.Go to a part store and ask for the adhesive for repairing rear view mirrors.It comes in a kit with the cleaner and the glue and instructions.You have to remove the mounting piece from the mirror and clean it also.Make sure you put the mounting piece on correctly or you will have to remove it again and it won`t be easy.Use a piece of tape for a mark on the out side of the windshield before you remove the glue from the inside so you know where the mirror was mounted.Follow the instructions carefully and this will take care of your problem.Auto Zone has this in stock.Hope this helps.Good luck.
Jun 28, 2010 | 1998 GMC Jimmy
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
Trunk trouble
Mine broke too. I have read that this is pretty common in this car...i think Scion needs to seriously take a look at this problem and come up with a solution.
Feb 24, 2010 | 2005 Scion tC
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
Installation
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Jan 04, 2010 | 1983 Ford Ranger
Re-assembly of 99 Blazer mirror to windshield
This is a relatively easy task, the bulk of the work has been for you. The rear view mirror assembly simply slides onto that metal block that was glued to your windshield. Your mirror mount (the part that slides onto the metal bracket) may be cut differently or shaped different from the rest of that part. you simply need to line that up with the metal mount on your windshield. slide the mirror on and tighten down the set screw if you have one. I've listed the steps below
1. find the base mount for your mirror (this is the bottom of the mirror that sits on the windshield)
2. look for a cut out or flat part of the mirror base.
3. line the flat part of the mirror base with the metal mount bracket on the windshield.
4. slide the mirror onto the metal bracket (this may require you to wiggle while you slide the mirror onto the metal bracket).
5. tighten the set screw on the mirror base ( this is important because your mirror will vibrate off the bracket if you don't.
Note some mirrors slide from the bottom of metal mount bracket and some slide from the top. it sort of depends on the manufacturer and/or the way the bracket was installed.
Hope this helps
Aug 04, 2009 | 1998 GMC Jimmy
Rearview mirror fell off windshield! Not broken...
the mirror should simply slide over the metal mount (button) that is glued to the window.
loosen the set screw on the mirror mount...
hold the rear view mirror mount on the glass just above the metal mount (wide end of plastic opening facing down)
slide it into place...
secure it by tightening down set screw you loosened earlier.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | 1998 GMC Jimmy
Compare laser Kat600 with escort 8500x50
The Escort 8500 X50 has better performance in all respects. As far as I am aware, Kat RDs are no longer being manufactured.
Mar 19, 2009 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
270 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Steve
Iron
Iron
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
