Question about HP DeskJet 812c InkJet Printer
Noise and blinking lights and printer appears frozen
My printer makes a loud noise as if something may be loose when I turn it on. The noise comes from the right side of the printer where the blinking lights both come on. I have disconnected the printer and reconnected.
Prior to this problem, I had sent several pages to the printer and am wondering if I overloaded it. I immediately cleared the documents to be printed, but it is still making this noise and just blinks.
  • Anonymous Dec 20, 2008
    When I try to print something It will blink the orange out of paper light and I have paper. It also makes this noise like gears grinding together hard.
  • emberphoto Feb 15, 2009
    Very same problem with sequentially flashing lights and loud grinding noise from rollers. Each time after a successful one page print, the orange out of paper light comes on, necessitating the whole merry-go-round all over again!
    Genius:
  • 2,785 Answers
Your printer needs servicing
Posted on Dec 09, 2008
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Loud noise coming from pump area
hello! as what you have describe it seems something is loose in your dishwasher. the best thing to do is to find it out right away before something goes wrong that is most hardly to be fix at all. okay? for more inquiry, please keep me in touch.
P.S. kindly rate this. a lot of thanks again!
Apr 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Feb 09, 2008 | Washing Machines
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
HP DeskJet 812c InkJet Printer Logo
425 people viewed this question
Ben Johnson
